download:
www.linuxcnc.org/iso/linuxcnc-2.8.2-buster.iso
either DD it to a USB (if in linux) or use etcher / rufus if in windows to copy to usb.
Boot and install.
then I would recommend installing the following
sudo apt install -y git geany grub-customizer git ethtool curl dpkg-dev inkscape gimp librecad freecad python3-opengl gnome-icon-theme xfce4-power-manager network-manager-gnome debhelper live-build
you can take out inkscape, gimp librecad and freecad if you want.... the rest I would just leave as they all have a purpose.
what exactly are you trying to set up?? lathe, mill, router, plasma??
then start synaptic and then just change the linuxcnc repositories to:
deb http://buildbot.linuxcnc.org/ buster master-rtpreempt
deb-src http://buildbot.linuxcnc.org/ buster master-rtpreempt
then run
sudo apt update
sudo apt -y upgrade
you will now have a working Master installed on buster.
