current master (2.9) building debs error?
4 years 5 months ago #243897 by tripwire
Great questions. I was actually creating my own linuxcnc gui in qtpyvcp, incorporating a lot of Probe Basic features. (Mainly because Probe Basic requires Python2 and I like the challenge of creating it myself image missing /media/kunena/emoticons/smile.png.)  As I said, I had a working Bullseye, lcnc2.9, qtpyvcp system running. I got pretty far along with my gui. Then, I think because of an improper pc shutdown, something broke. I started a topic about it here . My problem never got solved so I reinstalled Bullseye and ran into an issue installing lcnc2.9 which is the subject of this topic.
So, now I have a(nother!) fresh install of Bullseye and am ready to install lcnc2.9 and qtpyvcp.
I notice that the lcnc debs you listed in a previous post were all located in a Buster directory. Is this what I want?
I believe I did have success following the instructions for the Bullseye installation of lcnc2.9 and qtpyvcp on qtpyvcp.com.
Again, I really appreciate your help on this!!
Dave
4 years 5 months ago #243901 by robertspark
if you follow this / these you will get a working linuxcnc install of bullseye and 2.9
forum.linuxcnc.org/show-your-stuff/45039...etup?start=10#243886
I have had pyqtvcp running once with it earlier in the day, I am just testing the second install of pyqtvcp.... hence it WILL work up to the qtpyvcp part ..... after that I would wait.... I need to test something else
4 years 5 months ago #243910 by robertspark
I can now confirm that if you follow the sequence up to the
PROBE BASIC
on the above post of mine it WILL install
Debian Bullseye 11 + Linuxcnc + QTPyVCP and it WILL work.
4 years 5 months ago #243913 by tripwire
Thanks for that!!
I posted a few questions about the sequence in that thread. When I hear back, I'll give it a try.
Thanks again for all your work and help!
4 years 5 months ago #243915 by tripwire
Quick question-- do you use timeshift? It would be really nice to not have to reinstall everything on a little glitch...
4 years 5 months ago #243917 by robertspark
no never heard of timeshift, just found it now, thanks,
Time to create page: 0.151 seconds
