Installing LinuxCNC 2.9 or Master on Linux Mint 21
4 years 1 week ago #254688 by scotth
I have been having a problem with a failure to read error, which I thought was a timing problem. I installed all new updates other than Linux kernel 5.15.0-52.58. I have been testing for the last 2 days and NO ERRORS. I don't know which update fixed the issue.
4 years 2 days ago #255446 by jj80909
Thank you for creating this thread.  I have installed Mint21 / LinuxCNC 2.9 successfully and can launch a sim configuration of AXIS or Gmoccapy, but I am having trouble loading any sim configuration using qtvcp.  I get the following error when trying to do so:
Debug file information:
Note: Using POSIX realtime
  File "/usr/bin/qtvcp", line 12, in <module>
    from PyQt5 import QtWidgets, QtCore, QtGui
ModuleNotFoundError: No module named 'PyQt5'
Error in sys.excepthook:
  File "/usr/lib/python3/dist-packages/apport_python_hook.py", line 153, in apport_excepthook
    with os.fdopen(os.open(pr_filename,
FileNotFoundError: [Errno 2] No such file or directory: '/var/crash/_usr_bin_qtvcp.29999.crash'
Original exception was:
link (updating variable file): No such file or directory
2454
2500
Stopping realtime threads
Unloading hal components
I am not fluent in Linux...how do I go about getting the PyQt5 module installed?
Any help is appreciated.
3 years 11 months ago #255718 by tommylight
Links updated.
Heads up, now with version 6.0 of the RT kernel.
3 years 11 months ago #255760 by MarcoGaspar
Hello,
I installed the 6.0 rt kernel and when i try to install the linuxcnc deb file it says missing dependencies
Time to create page: 0.395 seconds
