Installing LinuxCNC 2.9 or Master on Linux Mint 21
3 years 11 months ago #256168 by tommylight
initialize: module '/home/alex/linuxcnc/configs/MJG_CNC/python/toplevel.py' init failed:
  File "/home/alex/linuxcnc/configs/MJG_CNC/python/toplevel.py", line 1, in <module>
    import remap
  File "/home/alex/linuxcnc/configs/MJG_CNC/./python/remap.py", line 1, in <module>
    from stdglue import *
ImportError: bad magic number in 'stdglue': b'\x03\xf3\r\n'
Interp ctor: can't instantiate Python plugin
    import remap
Python plugin configure() failed, status = -11
Python plugin required for prolog=, but not available: 108:REMAP = M6   modalgroup=6  prolog=change_prolog   ngc=rack_change  epilog=change_epilog
Python plugin required for epilog=, but not available: 108:REMAP = M6   modalgroup=6  prolog=change_prolog   ngc=rack_change  epilog=change_epilog
All those are errors related to remap/toolchange you have in one of your hal files, so not for this topic, much better to start a new topic if you intend to fix it, but, before you try that:
hm2/hm2_7i76e.0: error finishing read! iter=970
This is the issue we are having with new RT kernels not playing nicely with the network cards and dropping connection to Mesa board.
This means that even if you manage to fix the remap issue, this will not work for controlling a machine.
There is a whole topic regarding the kernel issue here, if you do not mind giving us some info about the PC used and what type of network card it uses, also some tips to try and see if it improves things:
forum.linuxcnc.org/27-driver-boards/4691...error-finishing-read
Thank you.
The following user(s) said Thank You: MarcoGaspar
3 years 11 months ago #256169 by tommylight
Added a warning to the original post about not using this tutorial for the time being due to some PC's having issues with network cards when using the new kernels.
Also "unsticky"-ed the topic.
Thank you.
The following user(s) said Thank You: rodw, zack, my1987toyota
3 years 11 months ago #257057 by tommylight
Updated links, latest build of LinuxCNC from 05/11/2022, and made it sticky again.
The following user(s) said Thank You: bkt, MarcoGaspar
3 years 11 months ago #257072 by MarcoGaspar
And the kernel insue ?
3 years 11 months ago #257091 by tommylight
If you have an Intel NIC, it works properly, at least on 5 PC's i tested in last 3 days.
Realtek does not.
3 years 11 months ago #257215 by andypugh
The following user(s) said Thank You: tommylight, bkt, my1987toyota
Time to create page: 0.455 seconds
