How to Install LinuxCNC?
- xenon-alien
- Thank you received: 4
01 Dec 2022 08:02 #258211
by xenon-alien
Replied by xenon-alien on topic How to Install LinuxCNC?
Today I have updated to the last 2.9.0 ..... pre1.53... (MESA 7i96s)
With the PncConf made a Lathe configuration, but the stepgen2 on the spindle rotates only in one direction. In other direction the Spindle-Enable not activates the ssr. (and maxvel is too big for it 10 000 pulses per rev - will try later the electronic gears in the servo-drive )
What can be the problem?
Here are the configs.
- Thank you received: 4656
01 Dec 2022 09:22 #258218
Replied by andypugh on topic How to Install LinuxCNC?
(I can't open the .rar file)
What are the HAL connections to the spindle-enable?
- xenon-alien
01 Dec 2022 09:30 #258221
by xenon-alien
The PNCConf made the configuration...
01 Dec 2022 09:55 #258224
The HAL looks OK. can you use halmeter to look at spindle.0.on and see if that is set true for both directions?
Then look at the spindle-vel-cmd-rps signal and make sure that is non-zero in reverse?
- xenon-alien
01 Dec 2022 12:45 #258245
by xenon-alien
Tomorrow I will tryThe HAL looks OK. can you use halmeter to look at spindle.0.on and see if that is set true for both directions?
- xenon-alien
02 Dec 2022 01:10 - 02 Dec 2022 01:12 #258300
by xenon-alien
So, in revers direction no reactions on any pins...
What should I do, to make it work?
Last edit: 02 Dec 2022 01:12 by xenon-alien.
- xenon-alien
02 Dec 2022 02:15 - 02 Dec 2022 02:49 #258302
by xenon-alien
Replied by xenon-alien on topic How to Install LinuxCNC 2.9?
Made a config on a 2.8.4 version (for MESA 7i96s) and copied to the 2.9.0......
The same issue. Using step/dir for spindle.
On the 2.8.4 version - unknown stepgen MD..... MESA 7i96s driver, or board something...
Last edit: 02 Dec 2022 02:49 by xenon-alien.
02 Dec 2022 10:20 #258327
Replied by andypugh on topic How to Install LinuxCNC 2.9?
This is rather odd.
Can you check the stepgen.2.enable and velocity-command to make sure that is getting through?
I am wondering if there is a setting in the drive that is disallowing clockwise motion.
- xenon-alien
05 Dec 2022 01:57 #258564
by xenon-alien
NothingThis is rather odd.
05 Dec 2022 19:09 #258648
Press the button some more? In the screenshots you seem to be commanding 0.016666 rps (1 rpm) and that is probably slower than the spindle can run.
Time to create page: 0.356 seconds
