Installing LinuxCNC 2.9 on Raspberry Pi 4B with Preempt-RT kernel
3 years 9 months ago #261319 by RMS
looks cool - ha ha
thanks
RMS
3 years 9 months ago #261389 by RMS
After closer look at overclocking instabilities, I am leaning to conclusion that culprit might be in the wall transformer current deficiency.
3 years 9 months ago #261587 by RMS
@Alan
Few days ago, I have stumbled by calling “halcompile”, while trying making changes in userkin.comp
The $ sudo apt-get install linux-cnc will not work with our new kernel: Linux linuxcnc29 5.15.84-rt54-v8+ #1 SMP PREEMPT_RT Fri Dec 23 20:39:48 CET 2022 aarch64 GNU/Linux,
thus, we need to bring latest source from GitHub
With lovely receipt of installation brought by Alan, and already dependencies in our system in place the recipe for building linuxcnc-dev is below.
Here are the steps:
Ideally like before git the branch in your /home/pi directory
$ git clone github.com/LinuxCNC/linuxcnc.git linuxcnc-dev
#after you git go to src
$ cd linuxcnc-dev/src
$ ./configure --help
$ ./autogen.sh
# To check what options are available invoke configure with –help
$ ./configure –help
#I have decided to use only additional three parameters
$ ./configure --with-realtime=uspace --with-boost=yes --with-libusb-1.0
$ make -j4
$ sudo make setuid
$ source ../scripts/rip-environment
$ runtests
$ linuxcnc
Above last cmd will invoke build “in place” a new version of linuxcnc.
LINUXCNC - 2.10.0~pre0
Note:
Linuxcnc-dev 2.10.0~pre0 is confined in own directory and is not interfering with previous deb install
Worth to mention to novice members that selection between versions is easy.
A fresh terminal window without setting rip-environment
$ linuxcnc
Brings LINUXCNC - 2.9.0~pre1
However, after dwelling into subfolder scripts of linuxcnc-dev and setting source like below
$ source rip-environment
Linuxcnc-dev 2.10.0~pre0 will be chosen instead.
I must admit when I started working with linuxcnc it was confusing at the beginning.
Alan perhaps you can complement your instructions with my notes, so everything will be more compact.
RMS
The following user(s) said Thank You: Donno
3 years 8 months ago #263819 by JT
1. On Linux desktop computer
Everything in this section should be run on your Linux desktop computer. These commands were tested on Linux Mint 21, but any reasonably recent Debian distro should work.
1.1 Install Raspberry Pi Imager
sudo apt install rpi-imager
I just thought I'd mention that rpi-imager is not in Debian 13 for sure and I've not checked older Debian OS's.
Thanks for reminding folks about the Mesa Configuration Tool.
JT
3 years 8 months ago #263822 by JT
I didn't get very far until I had an error...
john@cave:~$ cd rpi-rt-64 john@cave:~/rpi-rt-64$ git clone --depth 1 https://github.com/remusmp/rpi-rt-kernel Cloning into 'rpi-rt-kernel'... remote: Enumerating objects: 9, done. remote: Counting objects: 100% (9/9), done. remote: Compressing objects: 100% (7/7), done. remote: Total 9 (delta 0), reused 6 (delta 0), pack-reused 0 Receiving objects: 100% (9/9), 6.17 KiB | 6.17 MiB/s, done. john@cave:~/rpi-rt-64$ ls notes.txt rpi-rt-kernel john@cave:~/rpi-rt-64$ cd rpi-rt-kernel john@cave:~/rpi-rt-64/rpi-rt-kernel$ make RASPIOS_IMAGE_NAME=raspios_full_arm64 rm -fr build make build raspios_image_name=raspios_full_arm64 make[1]: Entering directory '/home/john/rpi-rt-64/rpi-rt-kernel' mkdir -p build docker build --build-arg PLATFORM32= --build-arg RASPIOS_IMAGE_NAME=raspios_full_arm64 -t rpi-rt-linux . make[1]: docker: No such file or directory make[1]: *** [Makefile:16: build] Error 127 make[1]: Leaving directory '/home/john/rpi-rt-64/rpi-rt-kernel' make: *** [Makefile:6: all] Error 2 john@cave:~/rpi-rt-64/rpi-rt-kernel$
JT
3 years 8 months ago #263825 by tommylight
It is looking for Docker, although i wonder why, but
sudo apt install docker
should do just fine.
Time to create page: 0.178 seconds
