Installing LinuxCNC 2.9 on Raspberry Pi 4B with Preempt-RT kernel
3 years 9 months ago - 3 years 9 months ago #261012 by RMS
Dear All,
With ongoing extensive testing, of this kernel
Linux linuxcnc29 5.15.84-rt54-v8+ #1 SMP PREEMPT_RT Fri Dec 23 20:39:48 CET 2022 aarch64 GNU/Linux
Unfortunately, I have found few problems.
1. the virtual keyboard was not found by gmoccapy.
The solution was the installation of onboard and pygst
$sudo apt-get install onboard
$pip install pygst
Note:
The matchbox-keyboard in this kernel is defective
2. In gmoccapy when loading png the error box pops up:
Found an error!
The following information may be usefull in troubleshooting
File "/usr/lib/python3/dist-packages/gladevcp/hal_filechooser.py", line 56, in update
m=progress_re.match(stderr_line)
TypeError: cannot use a string pattern on bytes-like object
Solution:
TBD , we need to ask developer of gmoccapy.
However, the “axis” imports and processes the png’s and py’s OK
Thanks,
RMS
Last edit: 3 years 9 months ago by RMS.
3 years 9 months ago - 3 years 9 months ago #261070 by alangibson
Thanks for the report
1. I'll add that to the instructions
2. There may be a quick fix for that. Try this:
- Open file /usr/lib/python3/dist-packages/gladevcp/hal_filechooser.py
- Change this line
    stderr=subprocess.PIPE,
to
    stderr=subprocess.PIPE, text=True,
Last edit: 3 years 9 months ago by alangibson.
The following user(s) said Thank You: RMS
3 years 9 months ago - 3 years 9 months ago #261171 by RMS
Alan
it works thanks
RMS
P.S.1.      With the overclocking I suggest being cautious.  I was experiencing stability problem on CM4 and had to revert and clean cmdline.txt and config.txt from overclocking entries.
2.      While loading button macros with custom ‘png” graphics i am getting error. File “/usr/bin/gmoccapy”, line 5728, in <module>  app = gmoccapy(sys.arg)
File “/usr/bin/gmocappy”, line 1397, in_check_macro_for_image Image=line.split(“.”)[1] IndexError: list index out of range
Any clues?
Last edit: 3 years 9 months ago by RMS. Reason: add on info
3 years 9 months ago #261249 by alangibson
Good to hear.
1. I've added a note about needing an very large heat sink. I've been thrashing my RPi for a week straight now without problems.
2. I'll take a look and get back to you
3 years 9 months ago #261258 by RMS
Alan,
Thanks.
The instability I was experiencing was particularly related to network connection.
The CM4 has heatsink with a fan attached, so there must be some other type of issue.
BR,
RMS
3 years 9 months ago #261293 by andypugh
I have had decent results with the passive heatsink cases:
www.amazon.co.uk/dp/B082Y2RGMP
I haven't tried this style, but it looks like it might be at least as good, and it's more of a case.
www.amazon.co.uk/dp/B08L8M6GJ7
(Not promoting any particular supplier, just indicative of the style of case I am talking about)
Time to create page: 0.139 seconds
