Running SIM in VM for QTPlasmaC
- phillc54
- Thank you received: 2100
23 Jan 2023 08:56 #262727
by phillc54
Replied by phillc54 on topic Running SIM in VM for QTPlasmaC
One other option is to use VMware Fusion Player which is free, the tools for it don't require building and are already packaged in Debian.
The following user(s) said Thank You: Doug @ Design8Studio.com
- Doug @ Design8Studio.com
- Thank you received: 46
23 Jan 2023 08:57 #262728
by Doug @ Design8Studio.com
Replied by Doug @ Design8Studio.com on topic Running SIM in VM for QTPlasmaC
Wow, I never heard of this. Will check it out!
23 Jan 2023 09:31 #262730
So I apparently cannot use the free VMWare Fusion Player option since my MacOS is too old, and they did not have a free Fusion Player option back when their version of Fusion was compatible with my OS. :-|
- phillc54
23 Jan 2023 09:43 #262731
by phillc54
There is also UTM, the only issue I have with it on an Intel Mac is that the VM can't be paused.
- iOS 14 and macOS 11.3 are the minimum supported systems for UTM v4.x. Please use UTM v3.x for support down to iOS 11 and macOS 11
23 Jan 2023 09:45 #262732
I'm on MacOS 10.14
- phillc54
23 Jan 2023 09:49 #262733
by phillc54
In that case I think your best bet is to boot into the image that works correctly and then go into synaptic and remove every other linux-image.
23 Jan 2023 17:29 #262751
Will do. Thank you for the awesome advice! Much appreciated!!!
Time to create page: 0.221 seconds
