Thank you for sticking with me.
git clone github.com/LinuxCNC/linux.git linuxcnc-dev didn't work until I pre-pended https:// in front of github.com.
I had to cd into /src for ./autogen.sh to work ... I had been in /src running autogen earlier in the week, so I knew to do so.
./configure errored out because I didn't have GTK or the right version of GTK. To see what would happen I took the suggestion and did ./configure --disable-gtk. That may have been a foolish decision if the LinuxCNC GUI is trashed for lack of GTK. Then ./configure ran past GTK but encountered the same rigmarole as a few days ago about licensing, so I ended up doing ./configure --disable-gtk --enable-non-distributable=yes.
That last ./configure command yielded the success box.
I ran make. It bombed, saying "No module named yapps."
Since then, I haven't tried anything. I'm feeling that I have a cleaner copy of the code than in previous attempts and I don't want to ruin it by getting too creative.
Here's the output from make when it stops:
Compiling hal/hal_lib.c
Compiling rtapi/rtai_ulapi.c
Creating shared library liblinuxcnchal.so.0
ln -sf liblinuxcnchal.so.0 ../lib/liblinuxcnchal.so
Creating shared library libnml.so.0
ln -sf libnml.so.0 ../lib/libnml.so
Compiling rtapi/test_rtapi_vsnprintf.c
Linking test_rtapi_vsnprintf
Compiling hal/components/streamer_usr.c
Linking halstreamer
Compiling hal/components/sampler_usr.c
Linking halsampler
Compiling hal/components/panelui.c
Linking panelui
Compiling hal/user_comps/mb2hal/mb2hal.c
Compiling hal/user_comps/mb2hal/mb2hal_init.c
Compiling hal/user_comps/mb2hal/mb2hal_modbus.c
Compiling hal/user_comps/mb2hal/mb2hal_hal.c
Linking mb2hal
Compiling hal/user_comps/gs2_vfd.c
Linking gs2_vfd
Compiling hal/user_comps/hy_gt_vfd.c
Linking hy_gt_vfd
Compiling hal/user_comps/shuttle.c
Linking shuttle
Compiling hal/user_comps/xhc-hb04.cc
Linking xhc-hb04
Compiling hal/user_comps/sendkeys.c
Linking sendkeys
Syntax checking python script halcompile
Copying python script halcompile
Preprocessing thermistor.comp
File "../bin/halcompile", line 24, in <module>
from yapps import runtime
ImportError: No module named yapps
make: *** [hal/user_comps/Submakefile:89: objects/hal/user_comps/thermistor.c] Error 1
robert@debian:~/linuxcnc-dev/src$
