I have tried varying the J7 jumpers. According to Vital Systems documentation for the Motenc Lite boards, there is a bit 0 board ID jumper and a bit 1 board ID jumper, and when the jumper is installed the value is 0. Even if I'm misunderstanding the Vital Systems documentation, there are only four states those two J7 jumpers can be in, and I have tried all four. The debug output has not changed. I have also tried setting the debug output at 5 and at ALL, again with no change. Looking at the hal_motenc.c code, the two board ID values the code considers valid are 0 and 1. If the board ID is zero, then the code thinks the board is a Motenc-100 board. If the board ID is zero, then the code thinks the board is a Motenc-Lite board. If the board ID is not zero or one, then the hal_motenc code writes an error "unknown card detected."
After trying these variations, with no change in result, I'm wondering if there might be something funkier going on, like the hal_motenc code is looking for the board ID in the wrong place ... something like that.
My confidence in the board itself is high because it has run a CNC mill for seven or eight years, running under Ubuntu. This was the original installation of LinuxCNC you helped me with. Both J7 jumpers were installed when the board was running that original machine.
I'm thinking the code (specifically the hal_motenc driver) has evolved since then while the Motenc hardware has not. Back when we put the first machine together, the Motenc-Lite board was mainstream hardware and the code expected its use. Perhaps that isn't true any more.
