LinuxCNC on Raspberry Pi 5
2 years 11 months ago #286135 by flyingbrick
thankfully (kinda?) my machine is big enough that the space required by a tower PC is not worth factoring in. The electrical cabinet is bigger than many wardrobes
and it even has a nice swing out shelf for the computer :-D
The size is only kinda of benefit because i dont know when I'll ever machine anything that size, and I dont know where im going to park the lawn mower :-D
2 years 11 months ago #286136 by Cant do this anymore bye all
A 2nd hand PC that is able to run Linuxcnc with a Mesa card is cheaper than a Raspberry Pi, at least in most cases.
Tommy is the guru on second hand PCs for Linuxcnc, generally laptops are a no go, in case you were wondering.
2 years 11 months ago #286418 by Calysto
Replied by Calysto on topic LinuxCNC on Raspberry Pi 5
I've send Mesa an email about this.... for what it's worth.. That's the only thing I can do about it I guess...
A friend of my wanted to swap my Pi4 1GB to his 4GB version. Very happy with that!! For now I can go further with Linuxcnc 2.9.1.
They are talking about 2-3 times faster, but it feels like 4-5 times faster, booting, browsing, etc... Only running Linuxcnc is endless slower... ;-)
About power draw of the Pi5, when Linuxcnc will work on it, I wil just set the usb_max_current_enable in config.txt. 7c80, SSD and Pi5 together only use 10Watt in normal state.
2 years 11 months ago #286435 by Cant do this anymore bye all
It may take a while tho, hopefully not too long.
One thing of note, in raspi-config there's an option to switch between wayland & X11 backends, Under "Advanced Options" -> "A6". Without this option some of the interfaces wont run because of the references to X11 functions.
I've got xfce running on mine and it does seem a bit "snappier" but that could be "all in my mind".
One thing I really like is how easy it is to boot from USB. Tho I'm just using a flash drive ATM as I have a NVME hat on the way, which should be interesting.
2 years 10 months ago - 2 years 10 months ago #287409 by chuckp47
Replied by chuckp47 on topic LinuxCNC on Raspberry Pi 5
I installed this image (drive.google.com/file/d/1H_q0Ra-27ZDOhqu...x1f/view?usp=sharing) and it boots on my Pi5. Latency seems much better than Pi4. Is this the most recent thing?  I thought I saw something about SPI patches?
Last edit: 2 years 10 months ago by chuckp47. Reason: add link for reference
The following user(s) said Thank You: flyingbrick
2 years 10 months ago - 2 years 10 months ago #287412 by Cant do this anymore bye all
Still waiting on SPI patches. Not too sure how much traction it will get. Will probably need someone to join in and make some noise. I've lodged an issue on github, but no responses.
Maybe someone may like to ask a question on the emc mailing, as I can't do that myself. And the reasons why are not up for discussion.
Last edit: 2 years 10 months ago by Cant do this anymore bye all.
Time to create page: 0.456 seconds
