LinuxCNC on Raspberry Pi 5
2 years 10 months ago #287438 by chuckp47
Replied by chuckp47 on topic LinuxCNC on Raspberry Pi 5
I can spend some time on this. Can we start a DM conversation? I've built Linux deployments before.
2 years 10 months ago #287440 by Cant do this anymore bye all
The driver will need a rewrite, more than likely, due to the I\O being moved to the RP1 chip. So if you want to get into some driver coding go for it.
2 years 10 months ago #287477 by flyingbrick
Hi Cornholio, Stupid question- Lack of I/O support wont affect the 5's ability to run an ethernet card? (I have one on the way, still trying to decide what machine i want to use to drive it) Just my luck that there would be some weird conflict that means its a no-go.
2 years 10 months ago #287481 by Cant do this anymore bye all
Should be ok.
Haven’t tested it myself.
2 years 10 months ago - 2 years 10 months ago #287484 by chuckp47
It would be great if you could point me to some appropriate build instructions. I can look at the driver.  I'm plenty familiar with building Linux, but I'd love to have a pointer to the exactly correct repos.  I haven't easily found this on this forum yet.
Last edit: 2 years 10 months ago by chuckp47. Reason: More detailed request
2 years 10 months ago #287491 by Cant do this anymore bye all
You'll have to dive into the RP1 as the IO has been moved off the BCM2712, the RPi4 had the IO on the BCM2711.
I had a bit of play but decided to move to another setup.
linuxcnc.org/docs/html/code/building-linuxcnc.html
datasheets.raspberrypi.com/rp1/rp1-peripherals.pdf
datasheets.raspberrypi.com/bcm2711/bcm2711-peripherals.pdf
github.com/raspberrypi/utils/tree/master/pinctrl
Time to create page: 0.120 seconds
