- Thank you received: 426
There was no cmdline.txt. Creating one with this line didn't change anything.rodw post=287637 userid=20660I did a bit of reading. can you guys try adding this at the beginning of cmdline.txt?
video=HDMI-A-1:1920x1080M@60D
I also noticed that the RT patch 6.1,66 has been released and the 6.1.66 kernel was merged into the 6.1.y branch yesterday so it would be a good time to build another image.
Trying your image now. ... what username and pw does it take?This image can be downloaded from here
drive.google.com/file/d/16kKamxMKPdYAeJp...KLf/view?usp=sharing
At first glance everything seems to work regularly and the lowest value that did not show the "Unexpected realtime delay" message was
latency-test 12000
I installed this and it's quite nice. Much like the default Pi release, everything came up normally. The latency historgram looks good. I'm trying to talk to a Mesa 7c81. After I set it up for an XZ lathe I get this error report when launch. The key part seems to be:This image can be downloaded from here
Note: Using POSIX realtime
hm2_rpspi: Can't map peripherals: Invalid argument
hm2_rpspi: cannot map peripheral memory.
hm2_rpspi: rtapi_app_main: Invalid argument (-22)
./my_LinuxCNC_machine.hal:9: waitpid failed /usr/bin/rtapi_app hm2_rpspi
./my_LinuxCNC_machine.hal:9: /usr/bin/rtapi_app exited without becoming ready
./my_LinuxCNC_machine.hal:9: insmod for hm2_rpspi failed, returned -1
