XHC-WHB04B-6 and LinuxCNC 2.9.1
2 years 5 months ago - 2 years 5 months ago #300619 by PCW
Replied by PCW on topic XHC-WHB04B-6 and LinuxCNC 2.9.1
Sounds like the whb hal (postgiu.hal?) file is not linked-in
(I usually test this kind of issue by inserting a deliberate error in the file
to make sure its being used)
Last edit: 2 years 5 months ago by PCW.
2 years 5 months ago #300620 by westhedge
Hmmm... My ini shows this:
[HAL]
HALUI = halui
HALFILE = GantryMill.hal
HALFILE = custom.hal
HALFILE = toolchanger.hal
HALFILE = xhc_whb04b_6.hal
POSTGUI_HALFILE = gmoccapy_postgui.hal
POSTGUI_HALFILE = custom_postgui.hal
SHUTDOWN = shutdown.hal
In the end, because i used pncconf to generate the GantryMill.hal file I put this in my xhc_whb04b_6.hal file:
unlinkp halui.machine.is-on
net machine.is-on whb.halui.machine.is-on halui.machine.is-on
That seems to work. Jog dial works. Need to tweak the button functions, but I'll sort that out. Cheers!
2 years 5 months ago #300622 by PCW
having
net machine.is-on halui.machine.is-on
in GantryMill.hal
and
in xhc_whb04b_6.hal
would be identical
2 years 5 months ago #300623 by westhedge
I agree they *should* be identicial... weird thing is it didn't work out that way. It simply refused to work unless I put it all in the latter xhc_whb04b_6.hal file. Could be a version bug, who knows.
2 years 5 months ago #300625 by PCW
That doesn't make any sense.
 It makes no difference when or from where a net command is
executed as long as the connected pins are present.
(at least in any version of LinuxCNC I've used)
2 years 5 months ago #300626 by westhedge
I agree with you - it didn't make sense to me either based on my [admittedly limited] knowledge. I will do some more testing around this and document what I find.
Is it possible to see a log of what hal commands are actually executed in order on start? That might illuminate the issue.
Time to create page: 0.061 seconds
