XHC-WHB04B-6 and LinuxCNC 2.9.1
- Thank you received: 5330
14 May 2024 22:29 #300627
Replied by PCW on topic XHC-WHB04B-6 and LinuxCNC 2.9.1
Looks like the error is a signal name mismatch:
pncconf uses net machine-is-on but the XHC file uses net machine.is-on
- westhedge
14 May 2024 22:36 #300628
by westhedge
Replied by westhedge on topic XHC-WHB04B-6 and LinuxCNC 2.9.1
UGH!!!
You are 100% correct. I did not spot that variance (glasses???). OK! I can confirm hal works as expected after the edit. I am now going to go through the other errors I saw initially - I bet they are the same mismatches.
Thanks!
Thanks!
- Thank you received: 7488
14 May 2024 22:46 #300629
Replied by tommylight on topic XHC-WHB04B-6 and LinuxCNC 2.9.1
Twice i searched for typos and missed this... i need thicker glasses, or more sleepLooks like the error is a signal name mismatch:
14 May 2024 22:48 #300630
There _is_ a way to test for signals with just one pin
in hal but I have forgotten how this is done...
- vre
- Thank you received: 17
06 May 2025 15:10 #327859
by vre
Replied by vre on topic XHC-WHB04B-6 and LinuxCNC 2.9.1
When i start this pendant must push continuous mode button for jogging with
wheel is not press continuous it changes feedrate override.
How can fix this ?
How can fix this ?
Time to create page: 0.293 seconds
