XHC-WHB04B-6 and LinuxCNC 2.9.1
- Online
- Thank you received: 5326
14 May 2024 21:19 - 14 May 2024 21:19 #300613
Replied by PCW on topic XHC-WHB04B-6 and LinuxCNC 2.9.1
These statements are equivalent:
net a b1 b2 b3
net a b1
net a b2
net a b3
As long as 'a' is a signal and 'b1', 'b2' are pins
and you do not have more than one source pin.
net a b1 b2 b3
net a b1
net a b2
net a b3
Last edit: 14 May 2024 21:19 by PCW.
- westhedge
14 May 2024 21:19 #300614
by westhedge
Replied by westhedge on topic XHC-WHB04B-6 and LinuxCNC 2.9.1
Interesting...
So If I have just this one line:
net machine.is-on whb.halui.machine.is-on halui.machine.is-on
halshow shows this for the signal:
Signals:
Type Value Name (linked to)
bit FALSE machine.is-on
<== halui.machine.is-on
==> whb.halui.machine.is-on
But if instead I have these 2 lines:
net machine-is-on halui.machine.is-on
halshow shows:
Signals:
bit FALSE machine-is-on
Signals:
halshow shows:
Signals:
- Online
14 May 2024 21:30 #300615
No sure why halshow does that but halcmd prints the expected (identical) thing:
halcmd: net a hm2_7i95.0.inmux.00.input-00
halcmd: net a hm2_7i95.0.ssr.00.out-00
halcmd: show signal a
Signals:
bit FALSE a
<== hm2_7i95.0.inmux.00.input-00
==> hm2_7i95.0.ssr.00.out-00
(new session)
halcmd: net a hm2_7i95.0.inmux.00.input-00 hm2_7i95.0.ssr.00.out-00
Signals:
bit FALSE a
Signals:
bit FALSE a
(new session)
Signals:
bit FALSE a
- westhedge
14 May 2024 21:38 #300617
by westhedge
I think I have discovered the root of the problem:
if I do this all in JUST the WHB file:
net machine.is-on halui.machine.is-on
halshow shows the desired wiring.
But if I have the same exact lines in their respective separate main and WHB files, that's when the pin wiring breaks down.
So... maybe this has something to do with the way hal processes the net commands across files. I can say with certainty the two commands above on separate files = non-working WHB.
- Online
14 May 2024 21:44 - 14 May 2024 21:45 #300619
Sounds like the whb hal (postgiu.hal?) file is not linked-in
(I usually test this kind of issue by inserting a deliberate error in the file
to make sure its being used)
Last edit: 14 May 2024 21:45 by PCW.
- westhedge
14 May 2024 21:52 #300620
by westhedge
Hmmm... My ini shows this:
[HAL]
HALUI = halui
HALFILE = GantryMill.hal
HALFILE = custom.hal
HALFILE = toolchanger.hal
HALFILE = xhc_whb04b_6.hal
POSTGUI_HALFILE = gmoccapy_postgui.hal
POSTGUI_HALFILE = custom_postgui.hal
SHUTDOWN = shutdown.hal
In the end, because i used pncconf to generate the GantryMill.hal file I put this in my xhc_whb04b_6.hal file:
unlinkp halui.machine.is-on
That seems to work. Jog dial works. Need to tweak the button functions, but I'll sort that out. Cheers!
[HAL]
HALUI = halui
- Online
14 May 2024 22:01 #300622
having
in GantryMill.hal
and
in xhc_whb04b_6.hal
would be identical
in GantryMill.hal
and
in xhc_whb04b_6.hal
would be identical
- westhedge
14 May 2024 22:06 #300623
by westhedge
I agree they *should* be identicial... weird thing is it didn't work out that way. It simply refused to work unless I put it all in the latter xhc_whb04b_6.hal file. Could be a version bug, who knows.
- Online
14 May 2024 22:12 #300625
That doesn't make any sense.
It makes no difference when or from where a net command is
executed as long as the connected pins are present.
(at least in any version of LinuxCNC I've used)
- westhedge
14 May 2024 22:18 #300626
by westhedge
I agree with you - it didn't make sense to me either based on my [admittedly limited] knowledge. I will do some more testing around this and document what I find.
Is it possible to see a log of what hal commands are actually executed in order on start? That might illuminate the issue.
Time to create page: 0.980 seconds
