XHC-WHB04B-6 and LinuxCNC 2.9.1
- SkyMoCo
- Thank you received: 4
13 Nov 2023 13:29 - 13 Nov 2023 13:30 #285306
by SkyMoCo
XHC-WHB04B-6 and LinuxCNC 2.9.1 was created by SkyMoCo
I bought a new XHC-WHB04B-6 pendant and have the buttons working and display reporting the correct positions, but I cannot get the dial to work.
When I run the xhc-whb04b-6 in event mode (xhc-whb04b-6 -eu) I see events getting generated when I turn the dial.
When I run the xhc-whb04b-6 in hal mode (xhc-whb04b-6 -p), I see events for the other buttons and when I switch the setting to select the various axis, but I do not see any events when I turn the dial. I assume I should...
Attached are my hal files and outputs from the above two commands.
Anyone else have this working and be willing to see if they get hal events? That would at least give me somewhere to start digging.
Last edit: 13 Nov 2023 13:30 by SkyMoCo. Reason: Fixed spacing
- SkyMoCo
13 Nov 2023 22:20 #285338
by SkyMoCo
Replied by SkyMoCo on topic XHC-WHB04B-6 and LinuxCNC 2.9.1
- Thank you received: 4155
15 Nov 2023 20:53 #285567
Replied by rodw on topic XHC-WHB04B-6 and LinuxCNC 2.9.1
Are you in the right mode to enable Jogging? (Teleop)
- SkyMoCo
15 Nov 2023 22:02 #285571
by SkyMoCo
Ah, thanks. I found my problem. Not sure where this line came from but when I removed it my jog dial started worked. Just needed the right hint.
This is the line I removed. Not sure if shows this way on the screen, but this is one line...
net pdnt.mode.is-manual halui.mode.is-manual whb.halui.mode.is-manual whb.halui.mode.is-teleop
- poesel
11 Dec 2023 14:39 #287882
by poesel
Replied by poesel on topic XHC-WHB04B-6 and LinuxCNC 2.9.1
I have nearly the same problem as the OP (same pendant, buttons are working). I see the events from the dial when I run 'xhc-whb04b-6 -p', but there is nothing in hal. 'whb.axis.x.jog-counts' stays zero.
Attached are the .hal files. Any pointers to what is wrong are appreciated.
Thanks.
Thanks.
- CNC_Tux
10 Jan 2024 12:30 #290391
by CNC_Tux
Replied by CNC_Tux on topic XHC-WHB04B-6 and LinuxCNC 2.9.1
Hello friends of LinuxCNC,
i have exactly the same problem, with the XNC-WHB04B-6 ....... all buttons and switches are working, but i cant move any axis with the jogwheel. I think something is wrong in the code, because today i tested different versions of LinuxCNC
LinuxCNC 2.9.2 the WHB04B-6 jogwheel isnt working
LinuxCNC 2.8.4 the WHB04B-6 jogwheel isnt working
LinuxCNC 2.8.3 the WHB04B-6 jogwheel is working !!
Has anybody a solution to fix this problem ?
Thank you so much in advance for further informations.
best regards
Reinhard
best regards
Reinhard
- CNC_ANDI
- Thank you received: 31
11 Jan 2024 03:00 #290410
by CNC_ANDI
Replied by CNC_ANDI on topic XHC-WHB04B-6 and LinuxCNC 2.9.1
hello i have the same handwheel... works fine for me
followed this guide
followed this guide
- CNC_Tux
11 Jan 2024 13:15 #290446
by CNC_Tux
Hello Andi,
thank you so much, i know the Video of talla83, this guy is a pretty well teacher of Linuxcnc.
Today i tested a lot of things it different versions of Linuxcnc, and i have a hot suspect of the source of this problem.
With the version 2.8.4. with a configuration of a Mesa 7i76e is working very well, with the same configuration but with a Mesa 7i96S doesnt work the Jogwheel of the xhc-whb04b-6.
I rewritten the configuration by of the Mesa 7i76e to a Mesa 7i96S manually and its working too.
My big suspect is the pncconf program, i am sure here get the Hal a value that prevented to work the xhc-whb04b-6.
Tomorrow i will check something about the values in the hal, because i need to understand the source of the problem.
I will report my experience.
I see, a lot of people here has exactly the same problem.
- CNC_Tux
12 Jan 2024 02:51 #290482
by CNC_Tux
Now i found the reason about working and not working of the Jogwheel of the xhc-whb04b-6.
Its a issue with MESA 7i96S.
MESA 7i76e works without any problems, but with a MESA 7i96S is possible as well.
in a old configuration i found in the Hal ( was for MESA 7i76e ) "[HMOT](CARD0)"
in the new configuration i found "hm2_7i96s"
[HMOT](CARD0) is working in both configurations with the xhc-whb04b-6
i testet in the Linuxcnc Versions 2.8.4 and 2.9.2 .. in both Versions is working
My Configurations was made with Pncconf
The Inputs and outputs is to write in this way for using with 7i96s :
"[HMOT](CARD0).ssr.00.out-02" for output
"[HMOT](CARD0).inm.00.input-01" for input
My suspect is the issue the driver for the MESA Card 7i96S !
The solution is to change "hm2_7i96s" to "[HMOT](CARD0)" in your Hal
The following user(s) said Thank You: CNC_ANDI
- poesel
13 Jan 2024 11:15 #290571
by poesel
@CNC_Tux where did you change that?
The only reference to 'hm2_7i96s' I found in my configs is in my ini. I tried to exchange it as per above but that didn't work.
Can you maybe post your configs here? Thanks.
Time to create page: 0.132 seconds
