Latest Official LinuxCNC ISO
- my1987toyota
- Thank you received: 449
03 Feb 2024 23:54 #292358
by my1987toyota
Replied by my1987toyota on topic Latest Official LinuxCNC ISO
Finally got a chance to try it . It works, but I keep getting an error on a fresh install when trying to update/upgrade saying
usr/bin/dpkg error (1) and it looks like its pointing to linux 6.10 rt . I am guessing I may have a corrupted install disk.
- Thank you received: 7504
04 Feb 2024 06:59 #292372
Replied by tommylight on topic Latest Official LinuxCNC ISO
What is the exact error?
- my1987toyota
04 Feb 2024 08:19 - 04 Feb 2024 08:24 #292393
by my1987toyota
sub-process /usr/bin/dpkg returned an error code (1)
the 2 previous lines say
linux-image-6.1.0-17-rt-amd64
linux-image-rt-amd64
I made a fresh install disk this morning and got the same error . So I am pretty sure it's not the install disk.
It does it before trying to change to the mate desktop.
Last edit: 04 Feb 2024 08:24 by my1987toyota. Reason: adding info
04 Feb 2024 08:23 #292395
Screenshot?
Does it mention z50-raspi somewhere?
The following user(s) said Thank You: my1987toyota
- my1987toyota
04 Feb 2024 08:24 #292396
by my1987toyota
I added info to my above post
04 Feb 2024 08:27 #292399
forum.linuxcnc.org/9-installing-linuxcnc...-update-error#289920
Do read the post below as there is a typo there.
- my1987toyota
04 Feb 2024 08:48 #292402
by my1987toyota
Thanks tommylight I will look into it when I get back to my machine today.
- my1987toyota
04 Feb 2024 12:50 - 04 Feb 2024 13:10 #292424
by my1987toyota
I took a look at the post you quoted. Unfortunately I still couldn't get it to work after removing the # typo.
So I instead ran the Debian 12.4.0 netlist iso.,installed Mate then went into synaptic and installed linuxcnc-uspace . All seems to be working right now.
I could be imagining it but I thought their was a post stating doing it the way I just did but I can't find it.
Last edit: 04 Feb 2024 13:10 by my1987toyota. Reason: adding info
04 Feb 2024 13:54 #292433
No, you are not imagining it, yet!
I did mention that a lot lately, but i advise on using a full Debian ISO, Rod used to use netinstall.
Can you please post the result of
lsb_release -a
I need to confirm something, thank you.
lsb_release -a
- my1987toyota
04 Feb 2024 14:38 #292439
by my1987toyota
I just want to make sure you want me to do that for the full debian 12 linuxcnc install iso or the debian netlist iso with linuxcnc installed afterwards?
Time to create page: 0.149 seconds
