Latest Official LinuxCNC ISO
2 years 8 months ago #292433 by tommylight
No, you are not imagining it, yet! :)
I did mention that a lot lately, but i advise on using a full Debian ISO, Rod used to use netinstall.
Can you please post the result of
lsb_release -a
I need to confirm something, thank you.
2 years 8 months ago #292439 by my1987toyota
I just want to make sure you want me to do that for the full debian 12 linuxcnc install iso or the debian netlist iso with linuxcnc installed afterwards?
2 years 8 months ago - 2 years 8 months ago #292441 by my1987toyota
this is for the debian 12.4.0 netlist iso version
File Name: terminalcopy.txt
File Size:178 B
I am going to throw in a different drive and run the Debian 12 linuxcnc iso then post back give me about a half hour.
Last edit: 2 years 8 months ago by my1987toyota. Reason: adding info
2 years 8 months ago #292442 by tommylight
That is exactly what i needed, does not mention minor versions just Debian 12.
Thank you very much.
Can you also try
cat /etc/os-release
Should return more helpful info, hopefully.
2 years 8 months ago #292444 by my1987toyota
after I finish the install on the other drive I will get you that on both of them for reference.
2 years 8 months ago #292445 by my1987toyota
Debian 12 with XFCE and linuxcnc 2.9.2 install iso
fail file dump from terminal
File Name: linuxcnc2....dump.txt
File Size:1.06 KB
cat etc os release file
File Name: catetcosrelease.txt
File Size:323 B
now to put the other drive back in and post that one
Time to create page: 0.123 seconds
