- LinuxCNC
- Installing LinuxCNC
- Problem Installing LINUXCNC 2.9.2 (Faild to copy file from installation media)
- krakos
14 Jul 2024 20:55 #305169
by krakos
Replied by krakos on topic Problem Installing LINUXCNC 2.9.2 (Faild to copy file from installation media)
i have the same problem i got 5 ubs/sdcard and still cant copy files
- Thank you received: 7488
15 Jul 2024 06:28 #305200
Replied by tommylight on topic Problem Installing LINUXCNC 2.9.2 (Faild to copy file from installation media)
What are you using to write the image to USB?
And how are you writing them?
Simple copy does not work.
Try win32diskimager, balena etcher, rufus, and if all fails, give DD a try.
Also, disable UEFI in BIOS and enable compatibility mode, if possible.
- krakos
15 Jul 2024 08:23 #305210
by krakos
in my pc there is no uefi this is older pc with e8600
i instal clear debian bookworm without any issus
linuxcnc need conection to the internet when is installing?
- krakos
15 Jul 2024 10:46 #305221
by krakos
ubuntu-10.04-linuxcnc3-i386.iso is instaling witout any problems
PC is DELL Optiplex 960 RS-232 LPT C2D E8600
15 Jul 2024 13:42 #305229
That is a bit to old, but should be usable, so if you can install Debian BookWorm, open a terminal:
sudo apt update
sudo apt upgrade
sudo apt install linuxcnc-uspace
That will install everything needed.
sudo apt update
sudo apt upgrade
- LinuxCNC
