- Thank you received: 4
its not usb device fault, it is messed up iso file, i even burned DVD and it still fails, please prompt the build team to fix this, as steps to install manually on debian 12 only install 2.9.0 pre1When you get that error, try unplugging the USB, wait 5 seconds, plug it back in, wait 15 seconds then hit retry.
If that fails, try what Rod mentioned, and if that also fails, the USB is faulty or a memory module is in really bad condition and has to be changed as it will fail.
Maybe for you but many people have installed it without problems.
its the preempt kernel variant LinuxCNC_2.9.2-amd64.hybrid.iso that is borked
