New and Working RTAI debs for 2.9
2 years 2 months ago #308259 by Ray_TL00
Thank you very much, I will try your advice.
2 years 1 month ago - 2 years 1 month ago #310271 by PhilipME
onelaboratories.us/rtai_lcnc/     5.4.258 matching RTAI kernel and LCNC debs
onelaboratories.us/abc/   5.4.279 matching RTAI kernel and LCNC debs
To install on Debian 12 with linuxcnc-uspace already installed use : sudo apt purge linuxcnc*  and wait for apt to completely remove every trace of LCNC.
Trying to follow the instructions, but linuxcnc does not get removed and I get the following message when I issue  sudo apt purge linuxcnc*
Package 'linuxcnc' is not installed, so not removed
Philip
Last edit: 2 years 1 month ago by PhilipME.
2 years 1 month ago #310357 by NTULINUX
PhilipME,
Are you using a vanilla Debian install from their website? If so, LinuxCNC is not installed by default so you should be safe to proceed and skip that step.
If LinuxCNC is already installed (not run-in-place) then I'm not sure what's going on.
If you're ONLY using run-in-place, you can also skip the purge command as well, but do not try to use the run-in-place instance as it will not work with RTAI unless you've built it against the RTAI kernel debs that are listed in the first post of this thread.
The following user(s) said Thank You: PhilipME
2 years 1 month ago - 2 years 1 month ago #310487 by PhilipME
PhilipME,
Sorry if I confused you
I edited this post so many times because I am working full time on this error
this is the final edit I hope. Next time I will have new entry for the edit
so when I dpkg three of the files, I get no errors
only linuxcnc_2.9.2_amd64.deb gives me the error above
dpkg: dependency problems prevent configuration of linuxcnc:
 linuxcnc depends on libboost-python1.74.0 (>= 1.74.0+ds1); however:
  Package libboost-python1.74.0 is not installed.
 linuxcnc depends on libboost-python1.74.0-py311; however:
  Package libboost-python1.74.0-py311 is not installed.
 linuxcnc depends on libmodbus5 (>= 3.1.4); however:
  Package libmodbus5 is not installed.
 linuxcnc depends on libtk8.6 (>= 8.6.0); however:
  Package libtk8.6 is not installed.
 linuxcnc depends on libudev-dev; however:
  Package libudev-dev is not installed.
 linuxcnc depends on iptables; however:
  Package iptables is not installed.
 linuxcnc depends on blt; however:
  Package blt is not installed.
 linuxcnc depends on mesa-utils; however:
  Package mesa-utils is not installed.
 linuxcnc depends on python3-tk; however:
  Package python3-tk is not installed.
 linuxcnc depends on python3-numpy; however:
  Package python3-numpy is not installed.
 linuxcnc depends on python3-gi-cairo; however:
  Package python3-gi-cairo is not installed.
 linuxcnc depends on python3-opengl; however:
  Package python3-opengl is not installed.
 linuxcnc depends on python3-configobj; however:
  Package python3-configobj is not installed.
 linuxcnc depends on python3-xlib; however:
  Package python3-xlib is not installed.
 linuxcnc depends on libgtksourceview-3.0-dev; however:
  Package libgtksourceview-3.0-dev is not installed.
 linuxcnc depends on tcl8.6; however:
  Package tcl8.6 is not installed.
 linuxcnc depends on tk8.6; however:
  Package tk8.6 is not installed.
 linuxcnc depends on bwidget (>= 1.7); however:
  Package bwidget is not installed.
 linuxcnc depends on tclreadline; however:
  Package tclreadline is not installed.
 linuxcnc depends on tclx; however:
  Package tclx is not installed.
 linuxcnc depends on python3-pyqt5; however:
  Package python3-pyqt5 is not installed.
 linuxcnc depends on python3-pyqt5.qsci; however:
  Package python3-pyqt5.qsci is not installed.
 linuxcnc depends on python3-pyqt5.qtsvg; however:
  Package python3-pyqt5.qtsvg is not installed.
 linuxcnc depends on python3-pyqt5.qtopengl; however:
  Package python3-pyqt5.qtopengl is not installed.
 linuxcnc depends on python3-opencv; however:
  Package python3-opencv is not installed.
 linuxcnc depends on python3-dbus; however:
  Package python3-dbus is not installed.
 linuxcnc depends on python3-espeak; however:
  Package python3-espeak is not installed.
 linuxcnc depends on python3-dbus.mainloop.pyqt5; however:
  Package python3-dbus.mainloop.pyqt5 is not installed.
 linuxcnc depends on python3-pyqt5.qtwebengine | python3-pyqt5.qtwebkit; however:
  Package python3-pyqt5.qtwebengine is not installed.
  Package python3-pyqt5.qtwebkit is not installed.
 linuxcnc depends on espeak-ng; however:
  Package espeak-ng is not installed.
 linuxcnc depends on pyqt5-dev-tools; however:
  Package pyqt5-dev-tools is not installed.
 linuxcnc depends on gstreamer1.0-tools; however:
  Package gstreamer1.0-tools is not installed.
 linuxcnc depends on espeak; however:
  Package espeak is not installed.
 linuxcnc depends on python3-poppler-qt5; however:
  Package python3-poppler-qt5 is not installed.
dpkg: error processing package linuxcnc (--install):
 dependency problems - leaving unconfigured
Processing triggers for libc-bin (2.36-9+deb12u8) ...
Processing triggers for mate-menus (1.26.0-3) ...
Processing triggers for desktop-file-utils (0.26-1) ...
Processing triggers for mailcap (3.70+nmu1) ...
Processing triggers for hicolor-icon-theme (0.17-2) ...
Processing triggers for man-db (2.11.2-2) ...
Processing triggers for shared-mime-info (2.2-1) ...
Errors were encountered while processing:
2 years 1 month ago #310511 by PhilipME
PhilipME,
I installed fresh copy of bookworm
2 years 1 month ago #310521 by PhilipME
Thank you and apology again for dump questions
It is working now beautifull
I had to issue sudo apt --fix-broken install
and sudo apt-get install python3-pyqt5.qtwebkit
