This is a different question/issue.There is no point in looking for 279. Both versions of the same program start in the XYZ configuration and work normally. Both versions crash in the same way when working with XXYYZ.
If I go that way I will, absolutely, need to patch the kernel.To get a specific kernel you probably need to get the source from kernel.org
www.kernel.org/pub/linux/kernel/v5.x/
Follow a similar process to the attachment but I assume you won't need to patch the real time kernel
