New and Working RTAI debs for 2.9
9 months 3 weeks ago #341212 by cnbbom
Life has got more complicated. With proper kernel tuning, latency can be better with Debian 13. I am in the process of publishing a second video about this on YouTube. Please refer to my channel.  www.youtube.com/@MrRodW
The yet to be published video should be watched before the current one.
I watched the videos, and I have some information.
1. Every time I tried to do a clean install, it returned a firmware error rtl_nic/rtl8168h-2.fw, and I believe that because of this firmware error, the Windows boot option did not appear in GRUB. "When I learned about that utility you used, Balena Etcher, to create the installation pendrive, it solved the problem." Rufus with Windows was the cause of not creating the installation media 100%.
2. Some modifications suggested in the video did not have a better effect for me, and I believe it's because of my CPU; with Debian 13, I didn't have any success with PREEMPT_RT.
3. I did a new procedure with RTAI and observed that if I create a machine without spindle controls, I don't have crashes or the segfault error. But another issue arose: the created machine does not communicate with the LPT.
9 months 3 weeks ago #341213 by andypugh
The problem with the RTAI kernels is that they are stuck at v5 and they don't have such good hardware support as the preempt-rt kernels.
It is also possible that there is a problem with the 5.4.290 kernel as mentioned here:
forum.linuxcnc.org/9-installing-linuxcnc...-2-9?start=60#333143
5.4.279 is supposedly better, but I can't find it.
9 months 3 weeks ago - 9 months 3 weeks ago #341216 by cnbbom
The problem with the RTAI kernels is that they are stuck at v5 and they don't have such good hardware support as the preempt-rt kernels.It is also possible that there is a problem with the 5.4.290 kernel as mentioned here:https://forum.linuxcnc.org/9-installing-linuxcnc/53163-new-and-working-rtai-debs-for-2-9?start=60
would that be it?
Last edit: 9 months 3 weeks ago by cnbbom.
9 months 3 weeks ago #341217 by cnbbom
I saved some installation files; I meant to delete them, but because they contained important information, they remained.
9 months 3 weeks ago #341235 by tommylight
Time to create page: 0.506 seconds
