New and Working RTAI debs for 2.9
10 months 1 week ago - 10 months 1 week ago #340374 by Sekai
Hi. i install debian 12 clean and 5.4.290 with linuxcnc 2.9.4 and everything works great.
I mean for latency i have max 16us and sim works but when i create a step config with the wizard and try to load linuxcnc from the icon, the screen goes black and i have to restart the pc.
Edit:  i install 5.4.258-rtai with linuxcnc 2.9.2 and the same black screen but after a restart. Starting linuxcnc again it finaly gave me an error
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-5.4.258-rtai-amd64/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.9.2
Machine configuration directory is '/home/cnc/linuxcnc/configs/strung'
Machine configuration file is 'strung.ini'
INIFILE=/home/cnc/linuxcnc/configs/strung/strung.ini
VERSION=1.1
PARAMETER_FILE=linuxcnc.var
TPMOD=
HOMEMOD=
TASK=milltask
HALUI=
DISPLAY=gmoccapy
COORDINATES=X Z
KINEMATICS=trivkins coordinates=XZ
Starting LinuxCNC...
Found file(REL): ./strung.hal
Found file(REL): ./custom.hal
Starting DISPLAY program: gmoccapy
Debug file information:
File "/usr/bin/hal_manualtoolchange", line 61, in <module>
import nf, rs274.options
File "/usr/lib/python3/dist-packages/nf.py", line 19, in <module>
import tkinter
File "/usr/lib/python3.11/tkinter/__init__.py", line 3043, in <module>
/usr/bin/linuxcnc: line 977: 1268 Segmentation fault $EMCDISPLAY -ini "$INIFILE" $EMCDISPLAYARGS $EXTRA_ARGS
"""Checkbutton widget which is either in on- or off-state."""
SystemError: type Checkbutton has the Py_TPFLAGS_HAVE_GC flag but has no traverse function
/usr/bin/pidof: symbol lookup error: /usr/bin/pidof: undefined symbol: __libc_start_main, version GLIBC_2.34
/usr/bin/milltask exiting
<commandline>:0: milltask exited without becoming ready
/usr/bin/linuxcnc: line 660: 1279 Segmentation fault axis-remote --ping
1217
*** buffer overflow detected ***: terminated
Signal 6 (ABRT) caught by ps (4.0.2).
/usr/bin/ps:src/ps/display.c:71: please report this bug
/usr/bin/grep: symbol lookup error: /lib/x86_64-linux-gnu/libc.so.6: undefined symbol: __libc_enable_secure, version GLIBC_PRIVATE
Stopping realtime threads
Unloading hal components
Kernel message information:
[ 96.998896] I-pipe: head domain RTAI registered.
[ 96.998902] RTAI[hal]: mounted. ISOL_CPUS_MASK: 0.
[ 96.998910] SYSINFO - # CPUs: 1, TIMER NAME: 'lapic', TIMER IRQ: 4355, TIMER FREQ: 10390749, CLOCK NAME: 'tsc', CLOCK FREQ: 1662499000, CPU FREQ: 1662499000, LINUX TIMER IRQ: 4355.
[ 97.050990] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 97.051068] kstacks pool size = 524288 bytes
[ 97.051071] RTAI[sched]: hard timer type/freq = lapic/10390749(Hz)
[ 97.051074] linear timed lists.
[ 97.051077] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1662499000 hz.
[ 97.051080] RTAI[sched]: timer setup = 96 ns, resched latency = 0 ns.
[ 97.111842] USERMODE CHECK: OK.
[ 97.111847] USERMODE CHECK PROVIDED (ns): KernelLatency 3210, UserLatency 4927.
[ 97.111850] FINAL CALIBRATION SUMMARY (ns): KernelLatency 3210, UserLatency 4927.
[ 97.251101] RTAI[math]: loaded integrated musl libm version 1.2.3.
[ 97.607590] config string '0 out'
[ 97.956566] gmoccapy[1268]: segfault at 18 ip 00000000004ffef7 sp 00007ffe4af40600 error 4 in python3.11[41f000+2b3000]
[ 97.956585] Code: 40 ff 0f 85 d3 00 00 00 83 f9 0f 0f 8f 35 01 00 00 66 41 89 14 40 48 83 c2 01 49 83 c1 10 48 39 ea 74 32 0f b6 4f 08 49 8b 01 <48> 8b 70 18 48 89 f0 4c 21 d0 83 f9 07 7f ba 41 80 3c 00 ff 0f 85
[ 98.035750] hal_manualtoolc[1256]: segfault at 18 ip 00007fa6cfea6360 sp 00007ffe2d15db50 error 4 in libc.so.6[7fa6cfe36000+156000]
[ 98.035769] Code: 03 00 00 43 f6 44 3e 08 01 0f 84 4b 04 00 00 49 83 66 08 fe 48 8b 45 70 48 8d 55 60 66 48 0f 6e ca 66 48 0f 6e c0 66 0f 6c c1 <48> 39 50 18 0f 85 e6 05 00 00 4c 89 e1 0f 11 43 10 4a 8d 14 23 48
[ 98.144627] traps: milltask[1265] general protection fault ip:7f007f4e1b41 sp:7ffe63e76640 error:0 in libpython3.11.so.1.0[7f007f42a000+2d1000]
[ 98.307458] axis-remote[1279]: segfault at 0 ip 000000000055dc3a sp 00007ffd160584e0 error 6 in python3.11[41f000+2b3000]
[ 98.307477] Code: 0f 12 c8 66 48 0f 7e c6 66 48 0f 7e c9 48 85 d2 0f 84 22 02 00 00 48 83 c0 01 48 83 ea 01 48 89 43 20 48 8b 43 28 48 89 53 30 <48> 83 06 01 48 83 01 01 48 83 38 01 75 40 48 8b 78 18 48 8b 58 20
[ 100.956711] RTAI[math]: unloaded.
[ 101.006264] SCHED releases registered named ALIEN PEDV$D
[ 101.042832] RTAI[malloc]: unloaded.
[ 101.150248] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 101.161380] I-pipe: head domain RTAI unregistered.
[ 101.161387] RTAI[hal]: unmounted.
Last edit: 10 months 1 week ago by Sekai.
9 months 3 weeks ago #341138 by cnbbom
Happy 2026 to all.
Please inform me what kind of error this is when starting linuxcnc Rtai debian13
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-5.4.290-rtai-amd64/modules/linuxcnc
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.9.8
Machine configuration directory is '/home/cnc3axis/linuxcnc/configs/my-mill'
Machine configuration file is 'my-mill.ini'
INIFILE=/home/cnc3axis/linuxcnc/configs/my-mill/my-mill.ini
VERSION=1.1
TPMOD=
HOMEMOD=
TASK=milltask
HALUI=
DISPLAY=axis
COORDINATES=X Y Z
KINEMATICS=trivkins coordinates=XYZ
Found file(REL): ./my-mill.hal
Starting DISPLAY program: axis
task: 173 cycles, min=0.000004, max=0.013482, avg=0.009198, 0 latency excursions (> 10x expected cycle time of 0.010000s)
note: MAXV     max: 137.000 units/sec 8220.000 units/min
note: LJOG     max: 137.000 units/sec 8220.000 units/min
note: LJOG default: 13.700 units/sec 822.000 units/min
note: jog_order='XYZ'
note: jog_invert=set()
2950
malloc(): unsorted double linked list corrupted
3020
[  402.698255] I-pipe: head domain RTAI registered.
[  402.698257] RTAI[hal]: mounted. ISOL_CPUS_MASK: 0.
[  402.698259] SYSINFO - # CPUs: 4, TIMER NAME: 'lapic-deadline', TIMER IRQ: 4355, TIMER FREQ: 424048632, CLOCK NAME: 'tsc', CLOCK FREQ: 3392293000, CPU FREQ: 3392293000, LINUX TIMER IRQ: 4355.
[  402.702297] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[  402.702324] kstacks pool size = 524288 bytes
[  402.702325] RTAI[sched]: hard timer type/freq = lapic-deadline/424048632(Hz)
[  402.702325] linear timed lists.
[  402.702326] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3392293000 hz.
[  402.702326] RTAI[sched]: timer setup = 90 ns, resched latency = 0 ns.
[  402.715421] USERMODE CHECK: OK.
[  402.715422] USERMODE CHECK PROVIDED (ns): KernelLatency 1165, UserLatency 1867.
[  402.715423] FINAL CALIBRATION SUMMARY (ns): KernelLatency 1165, UserLatency 1867.
[  402.719591] RTAI[math]: loaded integrated musl libm version 1.2.3.
[  402.760494] config string '0 out'
 image missing /media/kunena/emoticons/ermm.png=====>>   [  403.068800] xfdesktop[871]: segfault at 18 ip 00007fe8f41d7dd7 sp 00007ffd5fbed7e0 error 4 in libc.so.6[7fe8f4161000+165000]
[  403.068814] Code: dd 07 00 48 83 ec 08 48 8b 4f 08 48 89 c8 48 83 e0 f8 48 3b 04 07 0f 85 a9 00 00 00 f3 0f 6f 47 10 48 8b 57 18 66 48 0f 7e c0 <48> 3b 78 18 75 7b 48 3b 7a 10 75 75 48 8b 77 10 48 89 50 18 66 0f
image missing /media/kunena/emoticons/ermm.png =======>>    [  404.365328] axis[3055]: segfault at 0 ip 0000000000530730 sp 00007fff6a8ab700 error 6 in python3.13[420000+31f000]
[  404.365333] Code: 41 54 55 48 89 fd 53 48 83 ec 18 48 8b 57 f0 48 85 d2 0f 84 32 02 00 00 48 8b 4f f8 48 8b 42 08 48 83 e1 fc 83 e0 03 48 09 c8 <48> 89 11 48 89 42 08 48 c7 47 f0 00 00 00 00 48 83 67 f8 01 64 4c
[  406.905822] RTAI[math]: unloaded.
[  406.960250] SCHED releases registered named ALIEN PEDV$D
[  406.961994] RTAI[malloc]: unloaded.
[  407.068242] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[  407.086079] I-pipe: head domain RTAI unregistered.
[  407.086083] RTAI[hal]: unmounted.
9 months 3 weeks ago #341141 by tommylight
From your error report:
And the subsequent "segfault" (segmentation fault), both pointing at something wrong with memory or memory subsystem, but from experience, RTAI can and will report that sometimes on some hardware despite memory being OK.
Some tips:
-if the PC has more than one memory module, yank all but one out and test them one by one, see if it crashes
-if you have another PC, yank the HDD from this one and plug it on the other one, see if it crashes.
9 months 3 weeks ago #341144 by andypugh
Do you _need_ RTAI? What is your latency with preempt-rt?
9 months 3 weeks ago #341152 by cnbbom
I confess that RT version 2.92 worked well for me, even using LPT with around 25000 latency. However, when I saw Debian 13, I believed I could achieve the same result, but the latency is extremely high, reaching 150 on the same PC that had 25000 latency with Debian 12. That's when I tried RTAI and got these errors. I'm trying to find another PC following Tommylight's advice in an attempt to get some answers.
9 months 3 weeks ago #341160 by rodw
Life has got more complicated. With proper kernel tuning, latency can be better with Debian 13. I am in the process of publishing a second video about this on YouTube. Please refer to my channel.  www.youtube.com/@MrRodW
The yet to be published video should be watched before the current one.
Time to create page: 0.442 seconds
