- Thank you received: 5
Thanks, Tommylight told me it was the same one I already had here.
The Kernel Headers are not available for download. Is it necessary, or can I use the one I have here?
The ones on the server are the ones you provided, so yes.
But you don't need them unless you are compiling from source.
And this link works for me... www.linuxcnc.org/dists/trixie/base/binar...ai-amd64-1_amd64.deb
Is this also the case with the 5.4.279 kernel?
The error consists of: creating a machine in linuxcnc, I follow these options that allow me to use automatic spindle control. But after completing the configuration and opening linuxcnc, the PC shuts down, and I need to reset the PC.
Yes, it happens with kernel 5.4.279.
Can you try commenting out the "addf pwmgen...." in the HAL file?
(this will prevent the spindle PWM working, but will give some indication where the problem might be)
I commented out a # in this line:
Yes, disabling that line makes everything work except for the PWM spindle.So, are you saying that
"addf pwmgen.make-pulses base-thread"
Causes the PC to shut down and need a reset?
Is it possible that your base-thread period is shorter than the base-thread latency?
