Pi4b and Pi5 users - What should go in a 2.9.3 image
- Thank you received: 4155
12 Jul 2024 17:35 #305038
Pi4b and Pi5 users - What should go in a 2.9.3 image was created by rodw
Guys, with the release of Linuxcnc 2.9.3 I was going to look at building new images for the Pi 4b and Pi 5 for the downloads page.
It looks like this will be able to use the 6.6.35 PREMPT_RT kernel. This is because kernel 6.6.35 was merged into the Pi kernel on 21 June 2024.
That is the latest Pi kernel version matching to a PREEMPT_RT patch.
There are also many changes to the build enviironment.
So here is your chance. If there are specific packages you think should be included in the official images, please list them on this thread.
I am still reluctant to include a network manager because of its affect on latency and an alternative method to set your wifi credentials is included.
Setting a fixed IP address is covered in the hm2_eth man page.
- Thank you received: 426
12 Jul 2024 20:10 #305040
Replied by Cant do this anymore bye all on topic Pi4b and Pi5 users - What should go in a 2.9.3 image
gvfs-backends, can't remember if that comes std or not. But lets you connect to other computers via all your usual network filesystems, even sftp if the other machine is running ssh (dont ask about windows on that one), but also smb shares.
Midnight commander, great for when you're on the command line and need a file manager, clone of the old Norton Commander, comes with a pretty good editor, imagine dos EDIT on steroids, can also connect to other Linux machines for transferring files.
Rather than jumping on the latest kernel bandwagon, I suggest looking at those available and see which one gives the best all round latency, yes I know that sounds a bit controversial, but you know sometimes I'm a bit odd.
It maybe that the 4 & 5 need different versions. Yeah I know not a real pleasant thing to do, and something difficult if you don't have the hardware at hand. But then again if there's only a poofteenth in it, go with whatever is the latest.
Oh and make sure that's stated very clearly in big stonking red letters where the config.txt and cmdline.txt files are. A lot (maybe just some) people assume that just because they are using a RPi that those 2 files are in a different place......the curious ones look at the sud dir of boot, others just give up and create config.txt where the Raspbian OS has it. And for those that have a bit of knowledge, kinds mention whilst the distro is based on Bookworm, the kernel is a Raspberry Pi kernel and supports overlays. A user the other day was under the impression that because it was a bookworm based distro the kernel didn't support overlays, cause the kernel Debian uses doesn't.
If not the case enable the spi interface by default, and maybe disable blue tooth. I usually disable sound, but that's a personal thing.
And on the release page change that bit that SPI is supported on the RPi5, if that hasn't already been fixed.
Another one from left field, since now with the update eeprom you can install an image directly from the net on the RPi5 and 4 this is not possible for this image. It's pretty cool, boot with blank media in the RPI, it connects to a server, downloads the RPi imager and then writes the image you choose from imager's list. I used this method to install Raspbian directly to a NVME ssd on the 5.
Plus it should know what I want to machine and do the CAD & CAM without any inpout from me.
(and no cad & cam needs to be installed, it just knows)
12 Jul 2024 21:12 #305042
Replied by rodw on topic Pi4b and Pi5 users - What should go in a 2.9.3 image
Thanks for the feedback.
Notes about the Pi5 and no spi is on the downloads page.
The kernel version is no different to what we have done previously. I page back through the Pi kernel commits from current day until I find where they merge a kernel version that aligns with an RT patch. We clone at that commit. it would be very time consuming to find earlier versions. Kernel 6.6.39 is the latest long term supported kernel but it does not have an RT patch and was not merged into the Pi Kernel so to be at 6.6.35 should be stable for a long time.
I don't think any of the programs you mention are included in the amd64 installer or Debian Bookworm. scp should be available to copy files from the command line to/from other PCs. Can you check it is there?
Can you advise the exact locations (eg. full path) of config.txt and cmdline.txt?
12 Jul 2024 21:26 #305043
Don't have an image to check ATM regarding the paths, had to clear some stuff from my desktop. From memory it should be /boot/broadcom/
You'll be able to check for sure when building.
scp is part of openssh-client deb.
gvfs-backends makes it easier to connect to servers from the file manager.
14 Jul 2024 07:55 #305141
Come on guys, Rod's willing to put the effort in.
How about putting some effort in to help.
- meister
- Thank you received: 502
16 Jul 2024 10:56 - 16 Jul 2024 12:29 #305369
by meister
Replied by meister on topic Pi4b and Pi5 users - What should go in a 2.9.3 image
a cam tool would be nice
multixmedia.org/debian-packages/python3-...bookworm_aarch64.deb
github.com/multigcs/viaconstructor
EDIT: and librecad
EDIT: and librecad
Last edit: 16 Jul 2024 12:29 by meister.
The following user(s) said Thank You: Cant do this anymore bye all
- swepeter
- Thank you received: 3
19 Jul 2024 05:33 - 19 Jul 2024 05:36 #305633
by swepeter
Replied by swepeter on topic Pi4b and Pi5 users - What should go in a 2.9.3 image
A kaybinding tool to joypad such as ds4 would be great
VNCServer would also be great to be able to remote in.
Remove the 5V warning =)
Last edit: 19 Jul 2024 05:36 by swepeter.
- LeslieTroyer
20 Jul 2024 17:28 - 20 Jul 2024 17:30 #305730
by LeslieTroyer
Replied by LeslieTroyer on topic Pi4b and Pi5 users - What should go in a 2.9.3 image
I agree with vncserver …and the ability to run/boot on m.2 media
Last edit: 20 Jul 2024 17:30 by LeslieTroyer.
20 Jul 2024 18:07 #305734
That's already there, but you'll need to write the image to your nvme drive.
Disable EEE on boot, will need to be setup as a service, I'll see if I can find the info I found the other day. I'll also check if the driver has a switch to do that as well.
I'm beginning to think the RPi5 is a bit of a lemon for Linuxcnc is some cases.
Honestly at its price point a mini x86 system is a better choice.
The basic Odroid H4 runs in at $99 USD, a little bigger front print.
The only advantage the RPi4 had over an x86 system in terms of use was the ability to use the SPI interface. With the RPi5 that's not an option. And using the GPIOs is more or less on par with using a Parallel port.
In saying that I'll still try and assist rod as much as possible .
- Thank you received: 7504
20 Jul 2024 20:47 #305741
Replied by tommylight on topic Pi4b and Pi5 users - What should go in a 2.9.3 image
VNC should not be included with official releases, it is a huge security risk.
Time to create page: 0.237 seconds
