- Thank you received: 4
scorbot-er-3
- robocidalmaniac
- Topic Author
2 years 1 month ago #310162
by robocidalmaniac
scorbot-er-3 was created by robocidalmaniac
I own a Scorbot-ER-3 Robotic Arm. I have LinuxCNC 2.9 running on a HP envy h8-1534. I tried to run the Scorbot example and get this error code:Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.9.0~pre1+git20230208.f1270d6ed7
Machine configuration directory is '/home/robocidalmaniac/linuxcnc/configs/by_machine.scorbot-er-3'
Machine configuration file is 'scorbot-er-3.ini'
INIFILE=/home/robocidalmaniac/linuxcnc/configs/by_machine.scorbot-er-3/scorbot-er-3.ini
VERSION=1.1
check_config: Unchecked: [KINS]KINEMATICS=scorbot-kins
PARAMETER_FILE=sim.var
TPMOD=
HOMEMOD=
TASK=milltask
HALUI=halui
DISPLAY=axis
COORDINATES=X Y Z A B
Starting LinuxCNC...
emc/iotask/ioControl.cc 786: can't load tool table.
Found file(REL): ./scorbot-er-3.hal
Debug file information:
Note: Using POSIX non-realtime
File "/usr/lib/python3/dist-packages/serial/serialposix.py", line 398, in _reconfigure_port
orig_attr = termios.tcgetattr(self.fd)
termios.error: (5, 'Input/output error')
During handling of the above exception, another exception occurred:
File "/usr/bin/scorbot-er-3", line 56, in <module>
serial = serial.serial_for_url(
File "/usr/lib/python3/dist-packages/serial/__init__.py", line 90, in serial_for_url
instance.open()
File "/usr/lib/python3/dist-packages/serial/serialposix.py", line 332, in open
self._reconfigure_port(force_update=True)
File "/usr/lib/python3/dist-packages/serial/serialposix.py", line 401, in _reconfigure_port
raise SerialException("Could not configure port: {}".format(msg))
serial.serialutil.SerialException: Could not configure port: (5, 'Input/output error')
./scorbot-er-3.hal:15: waitpid failed scorbot-er-3 scorbot-er-3
./scorbot-er-3.hal:15: scorbot-er-3 exited without becoming ready
13959
Stopping realtime threads
Unloading hal components
RUN_IN_PLACE=no
LINUXCNC_DIR=
INIVAR=inivar
HALCMD=halcmd
VERSION=1.1
TPMOD=
HOMEMOD=
TASK=milltask
HALUI=halui
DISPLAY=axis
instance.open()
13959
2 years 1 month ago #310180
Replied by Aciera on topic scorbot-er-3
I get the same error when I try to run the config without hardware (I don't have a Scorbot) so I would assume that this error indicates a problem related to communication with the Scorbot hardware. Maybe try running 'dmesg' and see if you can see any related errors in the output.
2 years 1 month ago #310188
by JT
Replied by JT on topic scorbot-er-3
You will need a real time kernel to run LinuxCNC.
This means you're using a non-realtime kernel.
JT
JT
2 years 1 month ago #310195
Indeed, the error does not appear running this on a machine with real time kernel.
Note that you may have to add the user account to the group 'dialout' to be able to access the serial port.
The following user(s) said Thank You: robocidalmaniac
2 years 1 month ago #310197
Replied by tommylight on topic scorbot-er-3
It is also looking for a serial port from Python...
- robocidalmaniac
- Topic Author
2 years 1 month ago - 2 years 1 month ago #310206
by robocidalmaniac
Replied by robocidalmaniac on topic scorbot-er-3
You are correct. I was trying to run a simulation on my HP envy h8-1534 computer to test the software. I am in the process of setting up a Dell Optiplex 980 SFF i5-650 3,2GHz 4GB Ram computer with a parallel port, to run this Scorbot-er-3 robotic arm. I prefer to shake out the software first before attaching to a live machine. I would like to know if anyone else has used (Copyright © 2020) andypugh software for running a Scorbot-er-3 through the parallel part?
Last edit: 2 years 1 month ago by robocidalmaniac. Reason: missing info
Time to create page: 0.307 seconds
