- Thank you received: 4
scorbot-er-3
- robocidalmaniac
- Topic Author
2 years 3 weeks ago #311512
by robocidalmaniac
Replied by robocidalmaniac on topic scorbot-er-3
I was able to make the change, and it works now. The 4th axis (3: -1305.7399) keeps going negative when I try to Home the Scorbot-ER-3 see attached photo.
2 years 3 weeks ago #311515
Might also need to add it to HOME_LATCH_VELOCITY, or it might not.
Wait, does it have homing switches?
Replied by tommylight on topic scorbot-er-3
If it is supposed to move the other way when homing, add a - in front of the HOME_SEARCH_VELOCITY in the ini file for that joint.The 4th axis (3: -1305.7399) keeps going negative when I try to Home the Scorbot-ER-3 see attached photo.
- robocidalmaniac
- Topic Author
2 years 3 weeks ago #311520
by robocidalmaniac
Yes it has homing switches please see attached photo.
I will try what you suggested and let you know.
- robocidalmaniac
- Topic Author
2 years 3 weeks ago #311670
by robocidalmaniac
Thank you everyone I now have it working, and am in the process of adding a Logitech dual action F310 controller as a pendant.
The Scorbot-ER_3 limit switches needed readjusting using MOTOR TEST, on the Eshed Robotic control box with the Arm repositioned close to home.
For anyone trying this here is what was done:
Slammed the Dell Optiplex 9010 with ALL accessories attached and turned on with NO internet. Launched LinuxCNC and selected other machines Scorbot-ER-3 adding an icon to desktop.
In LinuxCNC Terminal typed:
"sudo nano /usr/bin/scorbot-er-3"
changed
"/usr/bin/scorbot-er-3", line 40 from this:
serial.write(data)
to:
serial.write(data.encode())
and saved
Next in terminal typed:
halrun
loadusr -W hal_input -KRAL Dual
loadusr halmeter
tested the Dual Action F310 controller
Then typed:
Quit
Exit
Opened LinuxCNC Scorbot-ER-3 icon and in the "Machine" tab selected input "0" and typed in "loadusr -W hal_input -KRAL Dual" then execute. Closed tap and reopened and tested the Logitech dual action F310 controller Pendant input signals.
Had to readjust the limit switches on the bot again for homing.
. Next is calibration and editing the Scorbot-ER_3 hal to use the Logitech dual action F310 controller as a pendant.
It does run the supplied "LINUXCNC" example but very tiny letters. Also there is a gripper slide in the main LinuxCNC screen in the upper right corner that works using the mouse, not sure how to add to the G-Code yet or the Logitech Pendant which does not have Analog output. I tried to attach a video but was unable.
Again thanks for all of the help
changed
serial.write(data)
to:
and saved
halrun
loadusr halmeter
Then typed:
Quit
Exit
- robocidalmaniac
- Topic Author
2 years 2 weeks ago #312185
by robocidalmaniac
Please has anyone been able to use a Logitech Dual Action F310 controller as a pendant for a Robotic Arm? I am running LinuxCNC 2.9.2 and are able to get the Mill working with the F310 as a pendant, but not my Scorbot-ER-3 robotic arm. Please help
- robocidalmaniac
- Topic Author
1 year 11 months ago - 1 year 11 months ago #314555
by robocidalmaniac
If anyone is interested I now have a Logitech Dual action F310 controller working as a pendant in LinuxCNC for the Scorbot ER 3 Robotic Arm. I can post if anyone is interested.
Last edit: 1 year 11 months ago by robocidalmaniac.
Time to create page: 0.362 seconds
