scorbot-er-3
There are again several errors trying to access the serial port called from the scorbot-er-3.hal file, but this time it has no access to it (permission denied), so omit that line in hal.
Or if it has a serial and it has to be used, try searching for
arduino serial port permission denied
to add you user to the "dialout" group.
- robocidalmaniac
- Topic Author
- Thank you received: 4
below is the error report I get now, please help:
Error report created by /usr/lib/tcltk/linuxcnc/show_errors.tcl:
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.9.2
Machine configuration directory is '/home/robocidalmaniac/linuxcnc/configs/by_machine.scorbot-er-3'
Machine configuration file is 'scorbot-er-3.ini'
INIFILE=/home/robocidalmaniac/linuxcnc/configs/by_machine.scorbot-er-3/scorbot-er-3.ini
VERSION=1.1
check_config: Unchecked: [KINS]KINEMATICS=scorbot-kins
PARAMETER_FILE=sim.var
TPMOD=
HOMEMOD=
TASK=milltask
HALUI=halui
DISPLAY=axis
COORDINATES=X Y Z A B
Starting LinuxCNC...
emc/iotask/ioControl.cc 786: can't load tool table.
Found file(REL): ./scorbot-er-3.hal
Debug file information:
Note: Using POSIX realtime
File "/usr/bin/scorbot-er-3", line 68, in <module>
serial_write('X')
File "/usr/bin/scorbot-er-3", line 40, in serial_write
serial.write(data)
File "/usr/lib/python3/dist-packages/serial/serialposix.py", line 616, in write
d = to_bytes(data)
File "/usr/lib/python3/dist-packages/serial/serialutil.py", line 65, in to_bytes
raise TypeError('unicode strError report created by /usr/lib/tcltk/linuxcnc/show_errors.tcl:
RUN_IN_PLACE=no
LINUXCNC_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.9.2
VERSION=1.1
TPMOD=
HOMEMOD=
TASK=milltask
HALUI=halui
DISPLAY=axis
serial_write('X')
serial.write(data)
d = to_bytes(data)
raise TypeError('unicode strings are not supported, please encode to bytes: {!r}'.format(seq))
TypeError: unicode strings are not supported, please encode to bytes: 'X'
./scorbot-er-3.hal:15: waitpid failed scorbot-er-3 scorbot-er-3
./scorbot-er-3.hal:15: scorbot-er-3 exited without becoming ready
1381
Stopping realtime threads
Unloading hal components
Info report created by linuxcnc_info:
The file: /tmp/linuxcnc_info.txt
can be posted to a forum or a web site like:
pastebin.com
in order to provide information about the linuxcnc
system and configuration.
Date: Thu Oct 3 11:36:34 AM EDT 2024
UTC Date: Thu Oct 3 03:36:34 PM UTC 2024
this program: /usr/bin/linuxcnc_infError report created by /usr/lib/tcltk/linuxcnc/show_errors.tcl:
RUN_IN_PLACE=no
LINUXCNC_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.9.2
VERSION=1.1
TPMOD=
HOMEMOD=
TASK=milltask
HALUI=halui
DISPLAY=axis
Found file(REL): ./scorbotings are not supported, please encode to bytes: {!r}'.format(seq))
1381
pastebin.com
RUN_IN_PLACE=no
LINUXCNC_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.9.2
VERSION=1.1
TPMOD=
HOMEMOD=
TASK=milltask
HALUI=halui
DISPLAY=axis
serial_write('X')
serial.write(data)
d = to_bytes(data)
1381
pastebin.com
this program: /usr/bin/linuxcnc_info
uptime: 11:36:34 up 7 min, 1 user, load average: 0.45, 0.63, 0.39
lsb_release -sa: Debian Debian GNU/Linux 12 (bookworm) 12 bookworm
linuxcnc: /usr/bin/linuxcnc
pwd: /home/robocidalmaniac/linuxcnc/configs/by_machine.scorbot-er-3
USER: robocidalmaniac
LOGNAME: robocidalmaniac
HOME: /home/robocidalmaniac
EDITOR:
VISUAL:
LANGUAGE:
TERM: dumb
COLORTERM:
DISPLAY: :0.0
DESKTOP: lightdm-xsession
display size: 1280x1024 pixels (338x270 millimeters)
PATH: /usr/bin:/home/robocidalmaniac/linuxcnc/configs/by_machine.scorbot-er-3/bin:/usr/bin:/usr/local/bin:/usr/bin:/bin:/usr/local/games:/usr/games
uname items:
nodename -n: debian
kernel-name -s: Linux
kernel-vers -v: #1 SMP PREEMPT_RT Debian 6.1.76-1 (2024-02-01)
machine -m: x86_64
processor -p: unknown
platform -i: unknown
oper system -o: GNU/Linux
/proc items:
cmdline: BOOT_IMAGE=/boot/vmlinuz-6.1.0-18-rt-amd64 root=UUID=2a785ebd-a07c-4f37-b8c8-be78eb505b68 ro initrd=/install/gtk/initrd.gz quiet
model name: Intel(R) Core(TM) i5-3570 CPU @ 3.40GHz
cores: 4
cpu MHz: 3607.748
parport: 0000-0000 : parport0
serial: 0000-0000 : serial
Versions:
gcc: gcc (Debian 12.2.0-14) 12.2.0
python: Python 3.11.2
git: not_in_PATH
git commit: NA
tcl: 8.6
tk: 8.6
glade: not_in_PATH
linuxcnc_var all:
o
EDITOR:
VISUAL:
LANGUAGE:
TERM: dumb
COLORTERM:
DISPLAY: :0.0
uname items:
nodename -n: debian
machine -m: x86_64
/proc items:
cores: 4
cpu MHz: 3607.748Error report created by /usr/lib/tcltk/linuxcnc/show_errors.tcl:
RUN_IN_PLACE=no
LINUXCNC_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.9.2
VERSION=1.1
TPMOD=
HOMEMOD=
TASK=milltask
HALUI=halui
DISPLAY=axis
serial_write('X')
serial.write(data)
d = to_bytes(data)
1381
pastebin.com
EDITOR:
VISUAL:
LANGUAGE:
TERM: dumb
COLORTERM:
DISPLAY: :0.0
uname items:
nodename -n: debian
machine -m: x86_64
/proc items:
cores: 4
cpu MHz: 3607.748
Versions:
git: not_in_PATH
git commit: NA
tcl: 8.6
tk: 8.6
glade: not_in_PATH
linuxcnc_var all:
Versions:
git: not_in_PATH
git commit: NA
tcl: 8.6
tk: 8.6
glade: not_in_PATH
linuxcnc_var all:
LINUXCNCVERSION: 2.9.2
LINUXCNC_AUX_GLADEVCP: /usr/share/linuxcncError report created by /usr/lib/tcltk/linuxcnc/show_errors.tcl:
RUN_IN_PLACE=no
LINUXCNC_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.9.2
VERSION=1.1
TPMOD=
HOMEMOD=
TASK=milltask
HALUI=halui
DISPLAY=axis
serial_write('X')
serial.write(data)
d = to_bytes(data)
1381
pastebin.com
EDITOR:
VISUAL:
LANGUAGE:
TERM: dumb
COLORTERM:
DISPLAY: :0.0
uname items:
nodename -n: debian
machine -m: x86_64
/proc items:
cores: 4
cpu MHz: 3607.748
Versions:
git: not_in_PATH
git commit: NA
tcl: 8.6
tk: 8.6
glade: not_in_PATH
linuxcnc_var all:
/aux_gladevcp
LINUXCNC_AUX_EXAMPLES: /usr/share/linuxcnc/aux_examples
REALTIME: /usr/lib/linuxcnc/realtime
RTS: uspace
HALLIB_DIR: /usr/share/linuxcnc/hallib
PYTHON: /usr/bin/python3
dpkg -l '*linuxcnc*':
Desired=Unknown/Install/Remove/Purge/Hold
| Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
|/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
||/ Name Version Architecture Description
un linuxcnc <none> <none> (no description available)
un linuxcnc-dev <none> <none> (no description available)
un linuxcnc-doc <none> <none> (no description available)
ii linuxcnc-doc-de 1:2.9.2 all motion controller for CNC machines and robots (German documentation)
ii linuxcnc-doc-en 1:2.9.2 all motion controller for CNC machines and robots (English documentation)
ii linuxcnc-doc-es 1:2.9.2 all motion controller for CNC machines and robots (Spanish documentation)
ii linuxcnc-doc-fr 1:2.9.2 all motion controller for CNC machines and robots (French documentation)
un linuxcnc-sim <none> <none> (no description available)
un linuxcnc-sim-dev <none> <none> (no description available)
ii linuxcnc-uspace 1:2.9.2 amd64 motion controller for CNC machines and robots
ii linuxcnc-uspace-dev 1:2.9.2 amd64 PC based motion controller for real-time Linux
serial_write('X')
serial.write(data)
d = to_bytes(data)
Maybe this could give you an idea about how to fix this particular issue (although there might be others after that):
stackoverflow.com/questions/35642855/pyt...ted-please-encode-to
to:
- robocidalmaniac
- Topic Author
when i use HALRUN I get the same following error:
~$ halrun
halcmd: loadusr -W scorbot-er-3
serial_write('X')
serial.write(data)
d = to_bytes(data)
<stdin>:1: waitpid failed scorbot-er-3 scorbot-er-3
<stdin>:1: scorbot-er-3 exited without becoming ready
I believe I am also having Python issues please can you tell me when the first LinuxCNC with Scorbot-er-3 version was?
Try:I do not have write access to that file
Seems to have been added in Version 2.8please can you tell me when the first LinuxCNC with Scorbot-er-3 version was?
