linuxcnc-dev is missing?
2 years 2 weeks ago - 2 years 2 weeks ago #312297 by Benb
Replied by Benb on topic linuxcnc-dev is missing?
Hi marq. I use the internet while following he instruction by cuting and passing from the pdf file. I dont use cd roms.
I only use usb key to burn debian12 using rufus, after that all the debian installation is done through the internet, same for preempt and linux cnc rip all files are loaded through the internet.
Once you get Debian running open a shell (command window) cut tfrom he pdf command and past them nto command line. And try not to skip steps
Dont try to upload files from cd rom they are probley no compatible with existing filesd. Use one and only command window until you complete the procedure
Last edit: 2 years 2 weeks ago by Benb.
The following user(s) said Thank You: marq_torque
2 years 2 weeks ago #312352 by marq_torque
Replied by marq_torque on topic linuxcnc-dev is missing?
Hello Benb,
No i'm not using CD-ROM I'm trying to follow PDF steps with internet. Let me know what i'm doing wrong how to correct.
Thank You
2 years 2 weeks ago #312444 by Benb
It looks like you have debian in your e drive and its trying read files from it.
E: Unable to locate package libtool-bin
E: Package 'bison' has no installation candidate
E: Package 'flex' has no installation candidate
E: Unable to locate package libelf-dev
E: Unable to locate package libacl1-dev
2 years 2 weeks ago - 2 years 2 weeks ago #312524 by marq_torque
Hello Benb,
I was able to reach till here
cnc@cnc:~/dev/linuxcnc/src$ ./autogen.sh
cnc@cnc:~/dev/linuxcnc/src$ ./configure --with-realtime=uspace
checking for c++... c++
checking whether the C++ compiler works... yes
checking for C++ compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether the compiler supports GNU C++... yes
checking whether c++ accepts -g... yes
checking for c++ option to enable C++11 features... none needed
checking for a BSD-compatible install... /usr/bin/install -c
checking whether c++ supports C++17 features with -std=gnu++17... yes
checking build toplevel... /home/cnc/dev/linuxcnc
checking installation prefix... run in place
checking for grep... /usr/bin/grep
checking for egrep... /usr/bin/egrep
checking for pkg-config... /usr/bin/pkg-config
checking pkg-config is at least version 0.9.0... yes
checking for gcc... gcc
checking whether the compiler supports GNU C... yes
checking whether gcc accepts -g... yes
checking for gcc option to enable C11 features... none needed
checking for stdio.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for strings.h... yes
checking for sys/stat.h... yes
checking for sys/types.h... yes
checking for unistd.h... yes
checking for rpc/rpc.h... no
checking for get_myaddress in -ltirpc... yes
checking for rpc/rpc.h... yes
checking for rtai-config... none
checking for xeno-config... none
checking for realtime API(s) to use... uspace
checking whether to enable userspace PCI access... yes
checking for libudev... yes - version 252
checking for cc version... not specified
checking whether the compiler supports GNU C... (cached) yes
checking whether gcc accepts -g... (cached) yes
checking for gcc option to enable C11 features... (cached) none needed
checking how to run the C preprocessor... gcc -E
checking for usability of linux/hidraw.h... yes
checking for usability of rpc/rpc.h... yes
checking for libmodbus3... yes - version 3.1.6
checking for libusb-1.0... yes
checking for libgpiod < 2.0.0... no
configure: WARNING: Could not find libgpiod, not building hal_gpio
checking for module installation directory... configuring for run-in-place
/home/cnc/dev/linuxcnc/rtlib
checking for glib... configure: error: no -- required until somebody makes glib optional
Is there any possibility to install Linuxcnc-Dev in standard 2.9.3 installation?
Last edit: 2 years 2 weeks ago by marq_torque.
2 years 2 weeks ago #312527 by Aciera
Replied by Aciera on topic linuxcnc-dev is missing?
do:
sudo apt install libglib2.0-dev
and try again
The following user(s) said Thank You: Benb
2 years 1 week ago #312544 by Benb
I hope what aciera suggested worked for you. Did you select to install Linuxcnc 2.9 or master 2.10. Because I only used this procedure to install Linuxcnc 2.9
Master might require additional/different dependencies
Time to create page: 0.521 seconds
