linuxcnc-dev is missing?
2 years 2 weeks ago - 2 years 2 weeks ago #312106 by tommylight
Replied by tommylight on topic linuxcnc-dev is missing?
EDIT:
Ignore this post, Benb pointed to info i missed, sorry.
This is not about installing RIP, it is about installing EtherCAT modules.
Download the whole project, not just the file you need, and try again.
Last edit: 2 years 2 weeks ago by tommylight.
The following user(s) said Thank You: marq_torque
2 years 2 weeks ago #312113 by Benb
Replied by Benb on topic linuxcnc-dev is missing?
Hey Tom, I am complete dummy when it comes to Linux OS. ?However, since I started using RIP I know where all pieces of the programs I loaded reside. For non linux savey it makes it easy to troubleshoot. As marq_torque indicated he does not know the location of hos files. marq_torque Once you install rip all your linux files will reside in Linuxcnc directory. If you follow the procedure all your linuxcnc files will reside in /dev/linuxcnc.
The following user(s) said Thank You: tommylight, marq_torque
2 years 2 weeks ago #312116 by tommylight
Sorry Benb, my bad, i just noticed it is looking for the homing.c file in the dev folder.
Thank you for bringing that to my attention, very much appreciated.
2 years 2 weeks ago #312132 by marq_torque
Replied by marq_torque on topic linuxcnc-dev is missing?
Attached is a step by step pdf file that I use to install linuxcnc rip, The procedure assumes you have installed clean Debian 12 in your computer.
Much thanks Benb, I have installed "LinuxCNC_2.9.2-amd64.hybrid" updated to 2.9.3 thru synaptic package. Can i follow the steps in PDF for this install?
2 years 2 weeks ago - 2 years 2 weeks ago #312214 by Benb
Couple of months ago I installed Linuxcnc rip on an intel i5 4the generation it installed flowlesslly. Try not to skip any steps, take your time don't rush otherwise you will have start all over again.
[edit] OOPS just realized that you loaded linuxcnc. You must start with Debian 12 os only nothing else.
Last edit: 2 years 2 weeks ago by Benb.
2 years 2 weeks ago #312272 by marq_torque
Hello Benb,
I have installed fresh Debian 12 and following the instruction in PDF,This is the result in first few commands
cnc@cnc:~$ sudo apt update
[sudo] password for cnc:
Ign:1 cdrom://[Debian GNU/Linux 12.7.0 _Bookworm_ - Official amd64 DVD Binary-1 with firmware 20240831-10:40] bookworm InRelease
Err:2 cdrom://[Debian GNU/Linux 12.7.0 _Bookworm_ - Official amd64 DVD Binary-1 with firmware 20240831-10:40] bookworm Release
  Please use apt-cdrom to make this CD-ROM recognized by APT. apt-get update cannot be used to add new CD-ROMs
Reading package lists... Done
E: The repository 'cdrom://[Debian GNU/Linux 12.7.0 _Bookworm_ - Official amd64 DVD Binary-1 with firmware 20240831-10:40] bookworm Release' does not have a Release file.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
cnc@cnc:~$ sudo apt upgrade
Building dependency tree... Done
Reading state information... Done
Calculating upgrade... Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
cnc@cnc:~$ sudo apt-get install -y build-essential autoconf libtool libtool-bin bison flex libssl-dev libelf-dev libacl1-dev
libncurses-dev dwarves fakeroot
Package flex is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
However the following packages replace it:
  libfl2
Package bison is not available, but is referred to by another package.
E: Unable to locate package libtool-bin
E: Package 'bison' has no installation candidate
E: Package 'flex' has no installation candidate
E: Unable to locate package libelf-dev
E: Unable to locate package libacl1-dev
bash: libncurses-dev: command not found
cnc@cnc:~$
Time to create page: 0.230 seconds
