Kernel 6.12 with PREEMPT_RT patches enabled - yet POSIX non-realtime (LM22.1)
1 year 9 months ago #320042 by rodw
Peter,
we have found that they are still issuing patches at kernel.org. Instead of Rokyas patch, try this official 6.13 patch
www.kernel.org/pub/linux/kernel/projects/rt/6.13/
Let us know how it goes.
1 year 9 months ago - 1 year 9 months ago #320045 by PCW
I did, I built 6.13-rc6-rt3 from kernel.org with the RT patches applied
but roykas patch was still needed.
How do I know it was needed? I stupidly thought I could create /sys/kernel/realtime
like normal file so for experimenting I did not need the patch. So I built the kernel
with the RT patch but not roykas patch first, and it failed in the expected
(POSIX non-realtime) way...
Last edit: 1 year 9 months ago by PCW.
1 year 9 months ago #320048 by rodw
Sounds like the issue is linuxCNC's method of detecting a RT kernel. Maybe we need to raise an issue and find a better way  at the source rather than Roykas work around.
1 year 9 months ago #320049 by Cant do this anymore bye all
I just used the sys_fs patch for realtime, that's all that is really required.
What I've notice with the patch set you end up having to set low_latency_desktop within the context of the preempt menu and then full preempt that shows up in the main section of general setup.
Without the patch set all the fully preempt option is in the preempt section under general along with the others as per previous kernel versions.
This happens whether building an arm kernel or a x86_64 kernel.
I went thru this royka during the course of quite a few posts. The guy's right on the money.
1 year 9 months ago #320051 by Cant do this anymore bye all
I've seen the sys_fs patch in the kernel rt patchset. Name is sysfs__Add__sys_kernel_realtime_entry.patch
1 year 9 months ago #320054 by PCW
Well, I built the stock 6.13-rc6-rt3 with RT patches from kernel.org and it does not create /sys/kernel/realtime
Time to create page: 0.274 seconds
