Kernel 6.12 with PREEMPT_RT patches enabled - yet POSIX non-realtime (LM22.1)
1 year 7 months ago #323805 by hitchhiker
Hi Royka in the past you give me a link to a kernel.. the link no more work.. :( is there a new version of a kernel for the latest linuxcnc? i am on mesa.. rtpreempt 6.1.0-31.
the kernel you link me was :
royka post=299706 userid=31446
Which kernel do you run at Debian 10? "uname -a"
What is the result of "cat /proc/cmdline" on Debian 10 and 12?
What is the result of "cat /proc/interrupts" ?
This kernel I've compiled last week by the way (6.9.0-rc5):
drive.google.com/drive/folders/1L28lG0zD...2XQJx?usp=drive_link
can you please help me.. i make fresh install on the same machine and done everything but the kernel is needed to get it work perfect.... i see that the kernel which came with the latest linuxcnc iso doesnt work like my machine before...
thanks
1 year 7 months ago #323878 by royka
I don't run debian 10, but Bookworm and actually use a rk3588 sbc which works very reliable. But here is the 6.12 kernel for x86 I've used before: drive.google.com/drive/folders/16Xlry00L...SlwznPLv?usp=sharing
But you can also download some from Debian, 6.13:
packages.debian.org/experimental/amd64/l...13-rt-amd64/download
And others:
packages.debian.org/search?keywords=linux-image-rt
1 year 7 months ago #323893 by rodw
Royka,
I hope you don't mind  linking to your 6.12 kernel from my how to document
docs.google.com/document/d/1jeV_4VKzVmOI...diY/edit?usp=sharing
1 year 7 months ago #323933 by royka
1 year 7 months ago #324292 by NTULINUX
Just so you guys know, I host my own 6.12 PREEMPT_RT sources with all the necessary real-time bits applied, including those for the i915 driver.
github.com/NTULINUX/linux
The 6.12 PREEMPT_RT kernel can lag behind so I manually update my sources to the latest 6.12 mainline kernel more often. My tree also allows building with the -O3 flag (compiler optimization flag) to speed up context switching, a typical culprit for latency spikes.
Just be sure you use the ntulinux/6.12.y-rt branch.
Cheers!
Time to create page: 0.261 seconds
