Update LinuxCNC 2.9.5 on debian 13
- unknown
- Thank you received: 323
17 Oct 2025 17:49 #336636
by unknown
Replied by unknown on topic Update LinuxCNC 2.9.5 on debian 13
Like I said there's a large thread covering just about everything related to the RPi image, wifi works fine by the way even better when the power saving is turned off. And there is even a sticky thats an index to that thread with the intention being topics are grouped together.
But sometimes I wonder why I bother sometimes.
- f355
- Thank you received: 7
17 Oct 2025 18:11 #336638
by f355
Replied by f355 on topic Update LinuxCNC 2.9.5 on debian 13
I'm sorry, what am I supposed to find in that thread? I don't have any questions about the LinuxCNC-provided image and never had. I came here to report a broken dependency in the apt repo, not to ask how to run LinuxCNC on an RPI.
Just to be clear, I have seen that thread, it is kinda hard to miss, and I've played with the image. For my personal preferences, I've decided to go with Raspberry Pi OS instead and I'm totally happy with it. What are we even discussing at this point?
- unknown
17 Oct 2025 20:12 #336642
by unknown
Well I was the one that produced the image, so any feed back good or bad (bad seems to be more helpful for improvement) is welcome. That's why I was interested in the reasons for the way you went. Yeah I get it's for personal reasons, but I would like to improve it to make it a better experience for other users and maybe make a consideration for others.
That's the way some threads go, the discussion can go another way. But if you don't want to be involved in the way the discussion as gone, which would appear to be the case, I shall no longer ask for any opinions nor input from yourself.
Good day sir.
Good day sir.
- f355
18 Oct 2025 00:54 #336646
by f355
Ah, I did not realize the images were yours, I thought it was the great cornholio dude (is that your old account, maybe?) and rodw who worked on them for some reason. That explains your interest in my setup, cool, I can certainly give you some feedback on why I chose RPi OS.
1. as mentioned before, I can't connect to wi-fi without running menu-config, and to run it, I need either a console or Ethernet. Connecting either is a hassle for me, I tend to run my Pi's headless with TigerVNC/noVNC. I've briefly looked at the rpi-image-builder the images are based upon and it seems like it's possible to mount the boot partition and edit some text file there so it sets stuff up on the first boot, but I have not dug deep - with RPi OS I can set that up in RPi Imager, together with the ssh key, the username and other stuff, it's much easier and it just works.
2. The kernel is custom-built from source with an RT patch, which makes it tricky to update it if I ever need to. There are now official RT kernels in the RPi apt repo and I can just apt install the new kernel. In general, the update cadence/mechanisms for the entire thing were - and still are - unclear to me.
3. I couldn't find the git repo where these images are built from. github.com/LinuxCNC/rpi-img-builder-lcnc is 2 years old, rodw's upstream is slightly newer but still older than the published images. It seemed like those images were built ad-hoc once by someone and just uploaded to the server, and that looked like a bit of a red flag to me.
4. cnc/cnc as default username/password is not something I want. I could create a user for myself, sure, but with RPi Imager I don't have to, so why bother.
5. this entire menu-config thing is not what RPi OS uses and what people - myself included - are familiar with. Not a big deal of course, but in general - Raspberry Pi has an official distro that is well-maintained and well-known, and I don't see why I, for one, should use something else in the second half of 2025. I understand why your images were built in the first place - PREEMPT_RT was not mainline at the time, RPi OS tended to push Wayland aggressively, you wanted a turn-key solution that less experienced people could just write to an SD card and use, my headless requirement is rather uncommon, etc., etc., but my personal preferences kicked in and I made a choice.
I hope that clarifies it!
- unknown
18 Oct 2025 03:42 #336650
by unknown
Here comes the "Grumpy Old Man Response".
1: That's your method. I was held back from including gnome network manager, a situation that didn't sit well with myself. Which is great as the user can have the option of enabling and disabling wifi as required. Adding this will be an improvement (as will the turnng off of the power saving features of the wifi, something I haven't recommended as thb I could see it being more hassle that it's worth to describe what is required, delving into systemd is required). Tho I did manage to sneak in gvfs-backends & gvfs-fuse. The zram swap thing was a bit of a debacle, something I blame myself for not fully checking the swap, which did rear it's head. Yes I get the ID Ten Tea award for that.
2: No patch was required for RT_PREEMPT, that was part of the Vanilla Kernel that was selected (which required thought put into it) and many thanks to a certain member that helped clarify a few things regarding that, any patches applied were those that the RPi Foundation has on their github, no trickery on our side. Until their particular patches make it to the mainline kernel they will always be applied.
3: You could of asked. Now this is really the bit I thought was a terrible assumption to make.You think those that manage Linuxcnc allow randoms to upload untested content to their server ? That is something extremely silly to assume, especially with 20 years of Linux experience.
4: Up to you.
5: That's people assuming things regarding the menu config. It has been clearly stated that whilst the image runs on the RPi and the kernel has been sourced via the RPi Foundation, it is Debian at is core and not RPi OS. Someone who thinks critically would assume that there would be differences in how things are done. Not understanding, excepting or realising that that things will always be the same way on a particular platform is rather naive (I would say silly myself).Apart from the kernel and a couple of RPi specific utilities, Debian was the easier solution. Basing anything on RPiOS requires removing a lot of Raspberry Pi Foundation branding from any image that was built and distributed. Hence the reason there was a switch from using Ubuntu in the emc2 days to Debian now.
Being able to actually install Linuxcnc & a required kernel onto a Raspi OS image would have been infinitely simpler, but the copyrighted branding becomes an issue. Which is their right and a good thing as well as it a protection for users, as a lot of people will blindly down load this or that. Hence scammers have it easy.
Supplying instructions for getting Linuxcnc on a Raspi image may have been one way, but people being what people are. I used to be a traffic controller and have lost confidence in people being able to follow instructions or wanting to.
4: Up to you.
- unknown
18 Oct 2025 03:45 - 18 Oct 2025 03:58 #336651
by unknown
Ok some further research has come up with some utils to build images based on 'the Rpi way".
Some of your comments have caused some rethink of the situation.
Now I think I should eat some humble pie. Would this be a situation where you would like to give a little more input. Consideration of your comments makes me thinks a more "Raspi OS" experience maybe a plus for the next generation of users. A new thread might be a better way to approach this. If you have the time it would be well appreciated.
Kind Regards
Rob
Kind Regards
Rob
Last edit: 18 Oct 2025 03:58 by unknown.
- f355
18 Oct 2025 04:38 #336653
by f355
1. All of this is my method. I'm not implying it is better or worse than yours, it's just mine.
2. There still is/was a patch that exposed /sys/kernel/realtime that linuxcnc required before 2.9.5, and the kernel is still built from source and baked into the image, as opposed to being installed from an apt repo. That makes the kernel update path unclear to me.
3. I could have asked, but I didn't. I never implied that "those that manage Linuxcnc allow randoms to upload untested content to their server", I'm sure the images are well tested and vetted. All I said is that it is completely non-obvious where the image builder sources are - I've just spent 10 minutes to find them again and I couldn't - and the official github has obsolete sources. That doesn't inspire much confidence in how well those images would be maintained in the future, don't you think?
5. I understand there are differences, it is obvious, I just don't want those differences. I gain nothing by learning how yet another distro is organized, it is wasted brain cycles. Now, your copyrighted branding point makes a lot of sense - I honestly did not think about that, and yes, it certainly adds a huge deal of motivation for not using RPi OS for pre-built images, but as I said even before your point, I totally get why your images exist. You've done a great job, I'm just not in the target audience for your work.
- f355
18 Oct 2025 04:43 #336654
by f355
Oh certainly and with pleasure! Feel free to create the new thread and shoot me a link.
The following user(s) said Thank You: tommylight, unknown
- Thank you received: 4154
18 Oct 2025 19:00 #336681
Replied by rodw on topic Update LinuxCNC 2.9.5 on debian 13
please read the notes on the downloads page to install wifi SSID. It is included but in the interest of latency, a network manager is not included.SPI works fine, it is in fact what I'm using - my little pet project is here, it is basically a rewritten Remora for a particular off-the-shelf machine. The servo latency is alright too.
I'm not insisting my approach is better for everybody, I just found it easier for myself to write a few shell scripts (install.sh and linuxcnc/pi_init/ in the repo) that set up things on the stock RPi OS image. The official linuxcnc image might have ssh enabled, but the wifi is not, or at least I couldn't find a way to configure it with my SSID quickly, and connecting Ethernet is about as much hassle as connecting a display![]()
- unknown
19 Oct 2025 02:00 #336695
by unknown
After some testing and having my machine up for 39 days a network manager doesn't really affect latency, well at least on the RPi5 (I replaced the Odroid with the RPi5). And it does make it easier to turn wifi off when needed.
Time to create page: 0.403 seconds
