sudo chrt 99 ping -i .001 -c 60000 -q [card_ip_address]
reports
anli@linuxcnc:~$ sudo chrt 99 ping -i .001 -c 60000 -q 192.168.1.121
[sudo] Passwort für anli:
PING 192.168.1.121 (192.168.1.121) 56(84) bytes of data.
--- 192.168.1.121 ping statistics ---
60000 packets transmitted, 60000 received, 0% packet loss, time 59999ms
rtt min/avg/max/mdev = 0.045/0.054/0.750/0.013 ms
I managed to get it up and running. First I disabled
- Secure boot
- Intel SpeedStep
- PCIe ASPM
- TurboBoost
in the bios. Than I could establish a connection and steer the axles. Afterwards I enabled one by one except PCIe ASPM again and I could steer the axles. I ran the above test in this state.
However, some errors remain:
2:52:38.591 WARNING Config: mousetweaks GSettings schema not found, mousetweaks integration disabled.
[GladeVCP.QTVCP.QT_ISTAT][WARNING] INI Parsing Error, No DEFAULT_SPINDLE_0_SPEED Entry in DISPLAY, Using: 200 (qt_istat.py:532)
[GladeVCP.QTVCP.QT_ISTAT][WARNING] INI Parsing Error, No MIN_SPINDLE_0_SPEED Entry in DISPLAY, Using: 100 (qt_istat.py:532)
[GladeVCP.QTVCP.QT_ISTAT][WARNING] INI Parsing Error, No MAX_SPINDLE_0_SPEED Entry in DISPLAY, Using: 2500 (qt_istat.py:532)
[GladeVCP.QTVCP.QT_ISTAT][WARNING] INI Parsing Error, No MAX_SPINDLE_0_OVERRIDE Entry in DISPLAY, Using: 1 (qt_istat.py:532)
[GladeVCP.QTVCP.QT_ISTAT][WARNING] INI Parsing Error, No MIN_SPINDLE_0_OVERRIDE Entry in DISPLAY, Using: 0.5 (qt_istat.py:532)
[Gmoccapy.GMOCCAPY.GETINIINFO][WARNING] Wrong entry [DISPLAY] CYCLE_TIME in INI File! Will use gmoccapy default 150 (getiniinfo.py:56)
58720259
hm2/hm2_7i76e.0: Smart Serial port 0: DoIt not cleared from previous servo thread. Servo thread rate probably too fast. This message will not be repeated, but the hm2_7i76e.0.sserial.0.fault-count pin will indicate if this is happening frequently.
File "/usr/lib/python3/dist-packages/gladevcp/hal_widgets.py", line 361, in <lambda>
lambda p: self.set_text(self.text_template % p.value))
I'll try to fix these - however if anybody has a quick idea what needs to be done to fix them your help is always appreciated
Thank you so far for your quick help to get the machine up and running again!
