Update LinuxCNC 2.9.5 on debian 13
- royka
- Thank you received: 135
22 Oct 2025 12:28 #336888
by royka
Replied by royka on topic Update LinuxCNC 2.9.5 on debian 13
But that's no fun, too easyYeah I could but I'd like to have a Trixe & Bookworm base image to work off. I'll get that going tomorrow (doesn't take too long) and have a look at the amd64 live-build for Trixie. Tho I'm a little desperate for disk space and had to drag a 2TB mechanical drive out of the cupboard.
This week's spending money went on RAM........so maybe in a couple of weeks I'll grab a NVMe drive.
Maybe if I stuck with Mach3 I wouldn't spend so much money, bugger I said the quiet part out load.
The following user(s) said Thank You: unknown
- unknown
- Thank you received: 323
22 Oct 2025 16:51 #336901
by unknown
Replied by unknown on topic Update LinuxCNC 2.9.5 on debian 13
The extra money would only be spent & wasted. (VB\Jack Daniels doesn't agree with my head, women are way too much hassle and I'm way way too decrepit for the the Circle Pit or Wall of Death nowadays ).
Must try to remember I'm not 18 anymore.
- f355
- Thank you received: 7
23 Oct 2025 00:39 - 23 Oct 2025 01:45 #336935
by f355
Replied by f355 on topic Update LinuxCNC 2.9.5 on debian 13
EDIT: I see there is already a workflow, but it doesn't build for arm64 or trixie, nor does it publish a github release with built packages. I'll see if I can fix that.
github actions/workflows support both amd64 and arm64, and are free to use for public repositories. I'll see if I can cook up something to build the packages using that, and pull-request it if it works. it could also potentially replace the buildbot altogether - I'm not sure if that's a good idea or not.
that said, I'm a bit short on time at the moment, so don't expect the PR tomorrow.
Last edit: 23 Oct 2025 01:45 by f355.
- unknown
23 Oct 2025 01:46 #336937
by unknown
Ok cool, git gets a bit over my head. I ain't real smart, but I used to lift heavy things .
- f355
23 Oct 2025 17:48 #336994
by f355
well, I got totally nerd-sniped by this, so here we go: github.com/LinuxCNC/linuxcnc/pull/3587
The following user(s) said Thank You: tommylight, rodw, Aciera
- unknown
23 Oct 2025 19:05 #337000
by unknown
Well done sir
- Thank you received: 4154
24 Oct 2025 02:38 #337028
Replied by rodw on topic Update LinuxCNC 2.9.5 on debian 13
Awesome work!
Time to create page: 0.434 seconds
