- Thank you received: 449
3D printed stuff, showcase it here
- my1987toyota
1 year 2 weeks ago #336535
by my1987toyota
Replied by my1987toyota on topic 3D printed stuff, showcase it here
Nicely done. I like your thrust dyno. How well do the 3D printed rotors hold up?
- Thank you received: 7491
1 year 2 weeks ago #336555
Replied by tommylight on topic 3D printed stuff, showcase it here
You mean propellers?
Pretty damn well, none have disintegrated so far and mostly the smaller ones stay intact when bumping into something while spinning, it takes a bit of effort to break them, and that is mostly due to printing direction.
Also i do not use PLA, ABS, HIPS, PETG, and lately PA6 Nylon.
The main issue are sanding them properly will improve efficiency a lot, and balancing them is a must sometimes.
Give it a try, you will be surprised how good they can be, just keep layer line longitudinally.
The following user(s) said Thank You: my1987toyota
- my1987toyota
1 year 1 week ago #336757
by my1987toyota
I always think of them as rotor blades like a helicopter. That said I will have to give it another try.
The last time I tried it they looked terrible. Lets just say they needed a lot of sanding, to say nothing
about being balanced. I should have taken a picture of them as a what it shouldn't look like. LOL
1 year 1 week ago #336774
1 piece props will require supports and that will require a lot of sanding and cleaning of all surfaces.
Multi piece ones are much easier and less cleaning and end up much more balanced.
A few nights back i had a light bulb moment, to print 1 piece props with no supports and at very low layer height so the next layer still has where to land, but i have yet to test how that ends up. I would start at 0.1mm for first test.
1 year 1 week ago - 1 year 1 week ago #336783
Replied by andypugh on topic 3D printed stuff, showcase it here
Have you tried PETG with PLA support? (easier said than done if you have a single extruder printer without an AMS)
Last edit: 1 year 1 week ago by andypugh.
The following user(s) said Thank You: tommylight, my1987toyota
1 year 1 week ago #336787
All i have left is 5 of Voron 2.4R2 and a single Creality CR-5 PRO, so none have multi material support, and i am in no rush to modify any, but yes i have seen that and it is easy to do when the bottom is flat even on single extruder machines.
I never needed multi color, either, but yes sometimes i wish i had already modified one of the Voron's, maybe someday when i get old ... hmm older...
