- Thank you received: 7491
3D printed stuff, showcase it here
5 years 1 month ago #221834
Replied by tommylight on topic 3D printed stuff, showcase it here
Oh how looks are deceiving, it is very small at 9.5X13CM only work envelope, so looks beefy!
Voron's are magnificent pieces of engineering and there are several versions to choose from:
Simple? = Voron Legacy
Top notch? = Voron 2.4
Middle with round rails? = Voron 1.6
Middle with linear rails? = Voron 1.8
Small and cute and bloody fast? = Voron 0 or 0.1 now.
The following user(s) said Thank You: BigJohnT, snowgoer540, my1987toyota
5 years 3 weeks ago #222405
The current state of the Voron Legacy build, starting to think i should have vent all in and do the 2.4, the waiting for parts is pretty much the same.
While waiting for those bloody alu profiles i did flash Klipper to an Arduino Mega, installed Klipper and klipper-screen on a RPI3B, added a very cheap 3 axis drive board with drivers set at /16, motors on XY/AB are Nema 17 0.9 degree ones so less torque but more resolution and driving 16 tooth pulleys.
BTW limit switches got mounted today in the only place i could fit them so that also required some programming to home Y first then X otherwise the X switch is never tripped!
The following user(s) said Thank You: phillc54, snowgoer540, my1987toyota
5 years 4 days ago - 5 years 4 days ago #224518
Last few days took modifying an Ender 5 Plus to CoreXY, added Hero Me cooling, direct drive, V6 Volcano hotend with 0.4mm nozzle, changed motors to 0.9 degree ones, added a RPI 3B+ that was collecting dust in the shop, flashed Klipper with MainSailOS on PI, did some tuning and initial tests so now it lays the first layer happily at 120mm/s and the rest at 160mm/s, but it still have a lot of ringing mainly because i forgot to mount one side of the HeroMe so now it just hands to the left side of the mount ? .
Also the 310 gram heavy motor has to go but can not find ... well anything here !
Last edit: 5 years 4 days ago by tommylight. Reason: fixed the link
The following user(s) said Thank You: shpatb
- shpatb
- Thank you received: 62
4 years 11 months ago #225432
by shpatb
Replied by shpatb on topic 3D printed stuff, showcase it here
Here is some of my progress messing around with my cr10v2, learning to 3D model things on my free time, beside education and work. One thing is for sure CAD is so powerful .
4 years 11 months ago #225454
Nice !
Leme grab the Titanic ...
4 years 11 months ago #225456
The following user(s) said Thank You: RotarySMP, elovalvo, besriworld, shpatb, my1987toyota
Time to create page: 0.168 seconds
