Beckhoff ethercat 64 with bit linuxcnc, How to install.
  • bob8020
  • Visitor
  • Visitor
2 years 8 months ago #294175 by bob8020
The EL3068 is working just fine here with an install from current .iso. Using it to measure vacuum with a 0-10v vacuum sensor and we halt motion if vacuum not sufficient.
Set scale to 10 and val reads 0-10v, into lincurve to get inches of mercury.
I've never used TwinCat... just linuxcnc :)
As it has 8 inputs would be a good choice if you want some manual knobs to turn, just feed 0-10v from a few pots and hook up the pins in hal.
2 years 8 months ago - 2 years 8 months ago #294273 by johntrevick
First off - thank you, thank you for your help.
Sorry for the delay answering - I thought I'd "save time" by making sure I was up to date by doing a fresh install and going to a rpi 5.   Only to find out that realVNC no longer works under bookworm and I couldn't get tigerVNC running.
quick note here:  the device has moved from my last posts from index 7 to 8 as I added another el1008 card in front of it.
If I have el5101 in the my config linuxcnc starts up and ethercat appears to be working for all devices except of course the el5102.
When I put el5102 in the ethercat-conf.xml it fails to start.
Here is the error:
LINUXCNC - 2.9.2
Machine configuration directory is '/home/cnc/linuxcnc/configs/wedm'
Machine configuration file is 'wedm.ini'
Starting LinuxCNC...
Note: Using POSIX realtime
Found file(REL): ./wedm_cmds.hal
Failed to register PDO entry: No such file or directory
LCEC: master 0 PDO entry registration failed
LCEC: failure, clearing config
LCEC: exiting
LCEC: returning -EINVAL
lcec: rtapi_app_main: Invalid argument (-22)
./wedm_cmds.hal:8: waitpid failed /usr/bin/rtapi_app lcec
./wedm_cmds.hal:8: /usr/bin/rtapi_app exited without becoming ready
./wedm_cmds.hal:8: insmod for lcec failed, returned -1
LinuxCNC terminated with an error.  You can find more information in the log:
    /home/cnc/linuxcnc_debug.txt
and
    /home/cnc/linuxcnc_print.txt
as well as in the output of the shell command 'dmesg' and in the terminal
In dmesg I get the following:
[ 1800.725115] EtherCAT 0: Starting EtherCAT-OP thread.
[ 1801.977068] EtherCAT ERROR 0-11: Failed to read mapped PDO entry.
[ 1801.977076] EtherCAT WARNING 0-11: Failed to read PDO entries for PDO 0x1600.
[ 1802.055062] EtherCAT WARNING 0-11: Failed to map PDO entry 0x60FF:00 (32 bit) to position 4.
[ 1802.055070] EtherCAT WARNING 0-11: Currently mapped PDO entries: 0x0000:00/0 0x0000:00/0 0x0000:00/0 0x0000:00/0. Entries to map: 0x6040:00/16 0x6060:00/8 0x607A:00/32 0x60FF:00/32
[ 1802.055086] EtherCAT WARNING 0-11: Failed to configure mapping of PDO 0x1600.
[ 1802.086095] EtherCAT WARNING 0-11: Failed to set number of assigned PDOs of SM2.
[ 1802.086117] EtherCAT WARNING 0-11: Currently assigned PDOs: (none). PDOs to assign: 0x1600
[ 1802.086130] EtherCAT WARNING 0-11: PDO configuration failed.
[ 1802.093055] EtherCAT ERROR 0-11: Failed to set SAFEOP state, slave refused state change (PREOP + ERROR).
[ 1802.094050] EtherCAT ERROR 0-11: AL status message 0x001E: "Invalid input configuration".
[ 1802.099055] EtherCAT 0-11: Acknowledged state PREOP.
[ 1802.103786] EtherCAT 0: Slave states on main device: PREOP, OP.
[ 1802.591778] EtherCAT WARNING: Datagram 000000003afefe45 (master-fsm) was SKIPPED 1 time.
[ 1802.727777] EtherCAT WARNING 0: 1 datagram UNMATCHED!
[ 1854.035335] EtherCAT 0: Master thread exited.
[ 1854.035432] EtherCAT 0: Starting EtherCAT-IDLE thread.
[ 1854.035505] EtherCAT 0: Releasing master...
[ 1854.035507] EtherCAT 0: Released.
[ 1854.091942] EtherCAT ERROR 0-9: AL status message 0x001B: "Sync manager watchdog".
[ 1854.092208] EtherCAT 0-9: Acknowledged state SAFEOP.
[ 1854.247696] EtherCAT 0: Slave states on main device: PREOP.
[ 1868.594153] EtherCAT: Requesting master 0...
[ 1868.594166] EtherCAT: Successfully requested master 0.
[ 1868.720697] EtherCAT ERROR 0 0:8: PDO entry 0x6000:13 is not mapped.
[ 1868.720909] EtherCAT 0: Releasing master...
[ 1868.721003] EtherCAT 0: Released.
The el3068 is working.  I have four potentiometers reading scale 0-10 and two with scale 0-11.
And before you say "These go to eleven" the machine is from 1980 and Spinal Tap movie is from 1984.
Last edit: 2 years 8 months ago by johntrevick.
2 years 8 months ago #294280 by scottlaird
Okay, interesting. So device #8 is the EL5102, and #10 and #11 are "DVS_ETHCAT_v1.004", right?
The error in dmesg is griping about slave #11, not slave #8, and the objects that it's griping about (0x6040:00, 0x6060:00, 0x607a:00, and 0x60ff:00) are what I'd expect to see with a CiA 402 servo or stepper drive.
If you comment out #11 in your XML, what happens?
2 years 8 months ago #294281 by scottlaird
Ahh, now I notice -- there's also a gripe for #8, about 0x6000:13, which is the frequency reading. Let me see what's up with that...
2 years 8 months ago #294284 by johntrevick
yes, 10 and 11 are cheap Chinese ethercat servo drives.
I haven't done much with them yet other than getting them to move.
I have a file DVS_ETHCAT_V1.12.xml config information from the vendor but I'm not sure what to do with it.
A little bit more information on the machine - the ethercat servo drives go through a 30:1 gear reduction and a 2:1 belt reduction to a ballscrew (0.100" per revolution)
Each ballscrew has a directly mounted encoder (5000 ppr) which is what I'm trying to hook up to the EL5102. The gear reducer has some backlash in it.
This is the way the machine was originally constructed. I'm not sure how I'll handle the encoder feedback vs drive feedback to linuxcnc but first I have to get all the bits working. I know I've seen similar done with motor encoders closing the loop to the drive and separate encoders or linear scales closing the loop to linuxcnc for position. Anyway, that's a problem for future me.
2 years 8 months ago #294285 by scottlaird
Got it. I'm currently alternating between poking at the EL5102 driver, writing generic CiA 402 stepper/servo control code, and playing with autogenerating XML files, so hopefully some or all of that will come in handy for you in the near future :-).
I just checked in a partial fix for the EL5102, it should show up as v1.17.1 shortly. For now, it just disables the 'frequency' and 'period' data. It shouldn't be that hard to fix, but it's probably not *terribly* useful for most people, and it'd be good to know that it's working without them first.
Time to create page: 0.265 seconds
