Ethercat with EL6751 CanOpen Master and JAT Servo Drives
  • JimPanski
  • Topic Author
  • Senior Member
  • Senior Member
6 years 8 months ago #156621 by JimPanski
Hi Forum,
I have an ongoing Setup with Beckhoff Ethercat components and CanOpen Servodrives.
For the first steps I am using only the BK1100 with an EL6751 and one drive attached.
I already set this up in Twincat 3.1.
Now my problem is to export the xml description in twincat for using it on the linuxcnc ethercat-config xml file.
Can anybody lead me a way to do this?
Thanks in advance!
Conny
6 years 8 months ago #156898 by chimeno
Hi @JimPanski
This device is not configured in linuxcnc-ethercat, you will have to create using the generic one, I will attach a configuration finalizing EL6751, first you have to send the configuration and then load the PDOs, I hope it helps you.
Chimeno
The following user(s) said Thank You: JimPanski
  • JimPanski
  • Topic Author
  • Senior Member
  • Senior Member
6 years 8 months ago - 6 years 8 months ago #156965 by JimPanski
Hello Chimeno,
first of all thank you very much for your post!
Unfortunately with this config the el6751 stays in preop.
Dmesg says: "sdo download 0x8003 aborted" subindex doesnt exist.
It seems that the config you posted is this one mr. brosette uses with those berger lahr type of drives.
My problem is in general how i can set those sdos up the right way because in my twincan setup i can communicate with my drive.
I attached the needed sdos in this .pdf file.
Your browser does not support embedded PDFs. Please download the file here: Download PDF.
Maybe this can help you make me the setup of the ethercat-config.xml understandable :)
if you need more input i can also search in the documents for this drive.
Thank you!
Conny
Last edit: 6 years 8 months ago by JimPanski. Reason: attachment corrected
6 years 8 months ago #157092 by chimeno
Hi @JimPanski
can you pass me the TWINCAT3 project to see if I can help you?
Chimeno
  • JimPanski
  • Topic Author
  • Senior Member
  • Senior Member
6 years 8 months ago #157151 by JimPanski
Hi Chimeno,
i hope the attached archive works for you. This is the archive of my basic setup in Twincat.
Thank you for your help!
Greetings
Conny
6 years 8 months ago - 6 years 8 months ago #157318 by chimeno
Hi @JimPanski
thanks for providing the configuration, I attached a new file with the proportionate configuration, it is not complete but if there is any progress, I do not have the device and it is difficult to prove it.
Greeting
Chimeno
Last edit: 6 years 8 months ago by chimeno.
  • JimPanski
  • Topic Author
  • Senior Member
  • Senior Member
6 years 8 months ago - 6 years 8 months ago #157901 by JimPanski
Hi Chimeno,
finally I got time for testing:
Warning: Spoiler!
:( this happens when i start it with the config file attached.
The only different from yours: This config file has only the 2 0x28FF set to the right values like i posted it before. (the win Twincat wont run with standard 1ms synchtime of the servo drive)
Sadly with your .xml File i also had no luck:
Warning: Spoiler!
In the meantime i think I got a better overview in Twincat, so that I could finally find the COE Startup SDOs which were used in the config xml file.
Do you have any further hints for me?
Greetings
Conny
  • JimPanski
  • Topic Author
  • Senior Member
  • Senior Member
6 years 8 months ago #158739 by JimPanski
Hi Chimeno,
Do you happen to have the such a EL6751 device available? I am asking because I am not getting any furher because I dont know what else i can also try.
So far I could find that "plopes9000" had likely the same issue (seen here at the ethercat thread ) but sadly no solution was posted :(
Greetings
Conny
6 years 8 months ago - 6 years 8 months ago #158811 by chimeno
Hi @Conny,
I do not have this device, I never use it, I can not help you much about this, although you can try to scan through the WIRESHARK program the data transmission that TWINCAT performs and see what is happening and replicate it in Linux, you can also publish it and look at it.
Chimeno
  • JimPanski
  • Topic Author
  • Senior Member
  • Senior Member
6 years 8 months ago #158948 by JimPanski
Hi Chimeno,
thanks for your offer. I will try to wireshark asap.
Do you think that may help If you have such a EL6751 and maybe one servo drive at hand? If you are interested I can provide both devices to you.
In the meantime I hope I can reach to plopes and try to get some hints.
Thank you very much!
Conny
Time to create page: 0.075 seconds
