Ethercat installation summary
3 years 9 months ago #261353 by db1981
don't use sudo.
Use the terminal for the rip install after executing rip-environment, then change to the the linuxcnc-ethercat folder.
- make clean
- make install
3 years 2 months ago #278268 by maghis
db1981, thanks for the suggestion (and for the cia402 component).
Waiting for
opmode_homing
before
controlword |= (home << 4)
totally worker, now I can start the drive homing procedure (opening a PR later today).
Now, while the drive is homing, I get a joint follow error from linux cnc because the joint position feedback is moving past the max error.
What is the best way to do this? Ideally I would like linuxcnc to ignore the feedback and wait until the drive is done homing, the set the home offset.
The following user(s) said Thank You: eduard
3 years 2 months ago #278282 by rodw
Replied by rodw on topic Ethercat installation summary
The solution here is to modify Dominic's component and set pos_fb=pos_cmd when the drive is homing.
The drive is moving outside linuxcnc's control so it gets confused
3 years 2 months ago #278295 by maghis
Thanks for the help Rod! (and for publishing your config)
It feels a little bit dirty to lie to the motion controller like that, but it makes sense.
What else should I change to do the final part of the homing?
I expect the sequence of events to look like this:
- joint.0.index-enable sets cia402.0.home
- the ECT60 starts following the homing procedure and moves to find the edge of the home sensor (specifically I'm using homing mode 22)
- linuxcnc sees that homing is complete and sets the machine coordinates to "HOME_OFFSET" from the ini <-- ???
How do I do the last step? Apologies but I'm completely new to linuxcnc, this is probably a super trivial thing :)
3 years 2 months ago - 3 years 2 months ago #278297 by maghis
Btw, per your suggestion, I added this line in "read_all":
  //home states   if (opmode_homing) {     // hack     pos_fb = pos_cmd;     stat_homed    = ((statusword >> 10) & 1) && ((statusword >> 12) & 1);     stat_homing   = !stat_homed && !((statusword >> 10) & 1);   }
Is that what you were thinking?
Last edit: 3 years 2 months ago by maghis.
3 years 2 months ago #278301 by rodw
Yes give that a go.
I could not get Dominic's component working with the ECT drives. Domininc I think homed to index on his drives ad that is not supported o n the ECT.
The solution is to create a custom homecomp  linuxcnc.org/docs/2.9/html/man/man9/homecomp.9.html
Have a good loook at homing.c and understand it before you start. BAsically you would skip a lot of steps and once homing is complete on the drive, Linuxcnc shold continue to do all the home offsets etc.
Time to create page: 0.078 seconds
