So I picked up where you left off here. I decided to ignore the following error issue and just set the following error limits to a large value and focus on the jumping after homing.Ok, I'll do some reading before continuing.
As an update, it looks like I'm pretty close.
The only changes I applied so fare are to the cia402 component:
- I wait for the ECT60 to confirm homing
[/code]Code:if (home) { opmode = OPMODE_HOMING; if (opmode_homing) { controlword |= (home << 4); } } - I lie with the current position to linuxcnc during homing [code]//home states if (opmode_homing) { // hack pos_fb = pos_cmd; stat_homed = ((statusword >> 10) & 1) && ((statusword >> 12) & 1); stat_homing = !stat_homed && !((statusword >> 10) & 1); } Current tested behavior is: - I press "home all" - joint sets cia402 home (joint.0.index-enable => cia402.0.home) - the drive follows the homing sequence and finds the edge of the home sensor - the drive exits the homing mode - at that point, the next "write all" sends again the current pos_cmd and the drive moves back to the position before the homing started I'll study homing.c - I was hoping to find a solution that didn't involve rebuilding linuxcnc (I'm running off of the 2.8.1 raspberry pi image right now).
