the holy grail...
- Padstar
- Visitor
12 Feb 2022 17:27 #234650
by Padstar
Replied by Padstar on topic the holy grail...
the help I'm, getting is always appreciated...
now i've added the current files i'm working with ... but intruth.. i'm not sure what needs to be in what...
this is the ethercat slaves info..
pad@linuxcnc:~$ ethercat slaves
0 0:0 PREOP + EK1100 EtherCAT-Koppler (2A E-Bus)
1 0:1 PREOP + EL1008 8K. Dig. Eingang 24V, 3ms
2 0:2 PREOP + EL2004 4K. Dig. Ausgang 24V, 0.5A
3 0:3 PREOP + EL2004 4K. Dig. Ausgang 24V, 0.5A
4 1:0 PREOP + Savch SDA2-E(CoE) Drive Rev1.3
but i'm scratching my head.. and getting nowhere fast...
can someone tell me what the minimim config i need... and how do i get to see the dro change when i turn the motor..
also ... (the quesitons are just pinging into my head.. but how is the scaleing delt with ...
thanks
Pb
thanks
Pb
- Padstar
- Visitor
14 Feb 2022 18:54 - 14 Feb 2022 19:02 #234851
by Padstar
hello ethercat peeps
so seems like i've uploaded the wrong ethercat-conf.xml here is the actual one..
which it wont seem to let me upload...
so here it is...
<masters>
<master idx="0" appTimePeriod="1000000" refClockSyncCycles="5">
<slave idx="0" type="EK1100"/>
<slave idx="1" type="EL1008"/>
<slave idx="2" type="EL1008"/>
<slave idx="3" type="EL2004"/>
<slave idx="4" type="generic" vid="000007e6" pid="53444132" configPdos="true">
<dcConf assignActivate="300" sync0Cycle="*1" sync0Shift="0"/>
<sdoConfig idx="2000" subIdx="0">
<sdoDataRaw data="70 17"/>
</sdoConfig>
<!-- Max motor current (6.0) -->
<sdoConfig idx="2011" subIdx="0">
<sdoDataRaw data="01 00"/>
</sdoConfig>
<!-- Closed loop -->
<syncManager idx="2" dir="out">
<pdo idx="1600">
<pdoEntry idx="6040" subIdx="00" bitLen="16" halPin="cia-controlword" halType="u32"/>
<pdoEntry idx="6060" subIdx="00" bitLen="8" halPin="opmode" halType="s32"/>
<pdoEntry idx="607A" subIdx="00" bitLen="32" halPin="target-position" halType="s32"/>
<pdoEntry idx="60FF" subIdx="00" bitLen="32" halPin="target-velocity" halType="s32"/>
</pdo>
</syncManager>
<syncManager idx="3" dir="in">
<pdo idx="1a00">
<pdoEntry idx="6041" subIdx="00" bitLen="16" halPin="cia-statusword" halType="u32"/>
<pdoEntry idx="6061" subIdx="00" bitLen="8" halPin="opmode-display" halType="s32"/>
<pdoEntry idx="6064" subIdx="00" bitLen="32" halPin="actual-position" halType="s32"/>
<pdoEntry idx="606C" subIdx="00" bitLen="32" halPin="actual-velocity" halType="s32"/>
<pdoEntry idx="6077" subIdx="00" bitLen="32" halPin="actual-torque" halType="s32"/>
</pdo-->
</syncManager-->
</slave>
</master>
</masters>
so here it is...
<masters>
</sdoConfig>
</sdoConfig>
<pdo idx="1600">
</pdo>
</syncManager>
<pdo idx="1a00">
</pdo-->
</syncManager-->
</slave>
</master>
</masters>
Last edit: 14 Feb 2022 19:02 by Padstar. Reason: a problem with attaching files
- Padstar
- Visitor
14 Feb 2022 19:07 - 14 Feb 2022 19:08 #234852
by Padstar
here is my linuxcnc.report
Last edit: 14 Feb 2022 19:08 by Padstar.
- db1981
- Thank you received: 276
14 Feb 2022 19:30 #234855
by db1981
Replied by db1981 on topic the holy grail...
related to this:
OK.. so what I have currently is some Backhoff ethercat IO.. and that was working... (whoop whoop.. ) well i was able to toggle one of the outputs on and off using the Hal tools...
I am pointing out that your ethercat-driver has worked before and you have been able to set/clear an output with the setp lcec.0.xxxxx command?
In your xml there are 2 typos, fix them and try again.
32 </pdo-->
33 </syncManager-->
remove the "--" at the line end.
32 </pdo-->
33 </syncManager-->
- db1981
14 Feb 2022 19:36 #234856
by db1981
and remove this line from your hal file :
loadusr -W lcec_conf lcec_conf.xml
you have two lines in the hal, that are calling lcec_conf
- Padstar
- Visitor
14 Feb 2022 20:55 #234862
by Padstar
thanks and thanks again ...
i'm doing lots of tests with HALCMD: but i'm just having no dice with the lcec side of things..
ive tried to point it at all my config files.. and everything.. but i just get errors...
Invalid parameter `/home/pad/linuxcnc/configs/PB_Mill/'
<stdin>:9: waitpid failed /usr/bin/rtapi_app lcec
<stdin>:9: /usr/bin/rtapi_app exited without becoming ready
<stdin>:9: insmod for lcec failed, returned -1
ive tried with the files here there and everywhere...
but its seeming not getting past this point..
Hmmmmmm
Hmmmmmm
- db1981
14 Feb 2022 21:20 #234864
by db1981
please descripe in detail what you have done above.
At this point i'm not shure if the installation of linuxcnc-ethercat has worked.
- db1981
14 Feb 2022 21:23 #234865
by db1981
and descripe the physically wiring of your ethercat system.
there is something strange:
- Thank you received: 4149
14 Feb 2022 21:38 #234866
Replied by rodw on topic the holy grail...
in your log, i see./PB_Mill.hal:14: execv(./lcec_conf): Permission denied
./PB_Mill.hal:14: waitpid failed ./lcec_conf lcec_conf
./PB_Mill.hal:14: ./lcec_conf exited without becoming ready
So to me that points to missing permissions in the relevant folder here:
deb install: /lib/linuxcnc/modules/
rip install: /linuxcnc-dev/rtlib/
does lcec_conf exist?
if so change its permissions. and see if the error goes away
Also its best to run linuxcnc from the command line for debugging so the errors are printed there for you. I use
linuxcnc -l
a lot to run the last config I opened.
linuxcnc -l
- Padstar
- Visitor
15 Feb 2022 11:08 #234910
by Padstar
thank you for all this help...
now in answer to the question about permissions..
are we saying i need to modify the permissions of both the folders.. or is that depending on what install I'm using..
yes there is a lcec_conf file.. (which i got from a git hub i think )
so I've no idea if that's right or wrong...
and also thanks for the command line tip on using the linuxcnc -I for the last config
as a secondary question ... is there any way to check that Lcec is installed correctly ... is there a tool, or script i can run to test.. ??
thanks
Pb
thanks
Pb
Time to create page: 0.422 seconds
