the holy grail...
- GuiHue
- Thank you received: 39
07 Apr 2022 08:32 #239519
by GuiHue
Replied by GuiHue on topic the holy grail...
I did only skip read this thread which I found searching for EL2004.
Are you still using this Beckhoff component? I have found that it likes to not work with linuxcnc-ethercat as the implementation in EL2xxx.c is faulty. It uses the same index as for other EL2xxx (0x7000) but that is not correct.
I came across the error while looking at sudo dmesg.
Might be worth looking into (if you are still at it).
- db1981
- Thank you received: 276
07 Apr 2022 10:09 #239525
by db1981
Replied by db1981 on topic the holy grail...
what kind of errors do you get?
At my configurations el2004s are working, and 0x7000 is the correct offset for Channel 0.
What is the Hardware / Software Rev of your card?
- GuiHue
07 Apr 2022 13:24 #239538
by GuiHue
Very interesting remark - I have only looked at the reference XML at the Beckhoff site, where I found a different Index (donÄ't have it with me right now).
How can I determine HW/SW rev?
- db1981
07 Apr 2022 13:50 #239545
by db1981
in Twincat system Manager
or with etherlab
"ethercat slave -p(pos number) -v"
or with etherlab
- GuiHue
07 Apr 2022 17:03 #239560
by GuiHue
That produces:
groot@grootethercat:~$ ethercat slave -p 10 -v
=== Master 0, Slave 10 ===
Device: Main
State: PREOP
Flag: +
Identity:
Vendor Id: 0x00000002
Product code: 0x07d43052
Revision number: 0x00000000
Serial number: 0x00000000
DL information:
FMMU bit operation: no
Distributed clocks: no
Port Type Link Loop Signal NextSlave
0 N/A down open yes 9
1 N/A down open yes 11
2 N/A down closed no -
3 N/A down closed no -
General:
Group: DigOut
Image name: TERM_DO
Order number: EL2004
Device name: EL2004 4K. Dig. Ausgang 24V, 0,5A
Flags:
Enable SafeOp: no
Enable notLRW: no
Current consumption: 130 mA
If I enter this as EL2004 in the xml file I get the following in dmesg:
[ 963.847456] EtherCAT ERROR 0 0:10: PDO entry 0x7000:01 is not mapped.
Device: Main
State: PREOP
Flag: +
Identity:
DL information:
General:
Group: DigOut
Image name: TERM_DO
Flags:
Enable SafeOp: no
Enable notLRW: no
- db1981
07 Apr 2022 17:24 #239562
by db1981
strange...
i'm shure this error is not EL2004 related, there must be some config pod count mismatch in front of the el2004. or the content of the SII Eeprom / Firmware has been reflashed and something went wrong. the rev and serial register should hold values....
Which devices are mounted in front of the el2004?
- GuiHue
07 Apr 2022 17:42 - 07 Apr 2022 17:56 #239563
by GuiHue
I tried a minimal setup. Its just an EK1100 and the EL2004.
groot@grootethercat:~/linuxcnc/configs/sim.axis$ ethercat slaves
0 0:0 PREOP + EK1100 EtherCAT-Koppler (2A E-Bus)
1 0:1 PREOP + EL2004 4K. Dig. Ausgang 24V, 0,5A
groot@grootethercat:~/linuxcnc/configs/sim.axis$ ethercat slave -p1 -v
=== Master 0, Slave 1 ===
Device: Main
State: PREOP
Flag: +
Identity:
DL information:
0 N/A down open yes 0
1 N/A down closed no -
General:
Group: DigOut
Image name: TERM_DO
Flags:
Enable SafeOp: no
Enable notLRW: no
I had the EL2004 in the mix with other devices. No problem there as long as I don't include it in the startup. To me the error regarding 0x7000 appears to point at the some problem all the time.
Another Update:
I installed TwinCat3 on a WindowsMachine and got it talking to the ethercat system:
It can manually trigger stat eand outputs just fine.
I exported the xml config. Shows no index 7000 anywhere - but a x3001:1 (to 4)
Last edit: 07 Apr 2022 17:56 by GuiHue.
- db1981
07 Apr 2022 18:33 #239568
by db1981
interesting, i just ad an el2004 to an Twincat2 Project and there the offset is 0x7000
What gives the output of "ethercat pdos -v -p"
- GuiHue
07 Apr 2022 18:48 - 07 Apr 2022 19:09 #239569
by GuiHue
As expected: 1600
I guess the easiest way is to use a generic config...
I guess one could change those in TwinCat3, but I'm concerned to brick something.
groot@grootethercat:~/linuxcnc/configs/sim.axis$ ethercat pdos -p1 -v
SM0: PhysAddr 0x0f00, DefaultSize 0, ControlRegister 0x46, Enable 1
RxPDO 0x1600 "Channel 1"
PDO entry 0x3001:01, 1 bit, "Output"
RxPDO 0x1601 "Channel 2"
PDO entry 0x3001:02, 1 bit, "Output"
RxPDO 0x1602 "Channel 3"
PDO entry 0x3001:03, 1 bit, "Output"
RxPDO 0x1603 "Channel 4"
PDO entry 0x3001:04, 1 bit, "Output"
Last edit: 07 Apr 2022 19:09 by GuiHue.
- db1981
07 Apr 2022 19:15 #239570
by db1981
ok, seems that your el2004 is from the "stoneage"
I just add different hardware revs to twincat and the very old ones are listed with the 3001 offset , and since rev10 the pdo seems to be 7000.
