Ethercat drive configuration woes
3 years 10 months ago #258734 by mwc
I did look at the Leadshine drives, and they appear to have more functionality, but I was put off by the price for what is essentially just a test setup before committing to an EtherCAT servo setup.
Plus the fact it took Leadshine several days to respond to a price enquiry for some servo drives, and I still haven't had a reply with prices, yet I can always rely on Lichuan for a next day response.
I have had a look through the Leadshine manual (Always better than a Lichuan one!), and they are using different registers, and have more information LEDs on them.
I'm almost reaching the point of asking if there are any UK regulars who'd like a drive to try and get working, as I've spent days on this now.
I did finally get movement earlier, but I've not been able to repeat that :/
3 years 10 months ago #258736 by wazza77
I had a similar response from Leadshine and Lichuan was the right price and I received it 10 days after I ordered here in Australia from china which these days is a modern miracle
3 years 10 months ago #258740 by petervg
Mwoah.. not sure the leadshine manuals or software are any better. I'm giving some feedback to my distributor during my testing, and let's say that the "alpha" stage the software and manuals are in is justified...
3 years 10 months ago #258746 by mwc
Config files are attached, in case I've missed something blindingly obvious.
3 years 10 months ago #258755 by petervg
I'm taking a look and comparing with mine.
Maybe a dumb remark from my side. but you do know you are referencing a different XML file in your HAL (conf.xml) then the one you attached here (conf_2022-12-06.xml)?
3 years 10 months ago #258758 by mwc
I had issues uploading the files, so I'm assuming the forum software added the date to the name.
They definitely don't have the dates on the actual computer.
If they did, loading the xml would generate an error and stop LinuxCNC from loading.
Time to create page: 0.155 seconds
