- Thank you received: 276
By the way, I read your drives manual page 23. If the document is correct The DS402 statemachine is not implemented as usual, they want to set mode of operation in front of the whole "enable statemachine" . The normal case is between state 2 and 3 in front of the last bit "enable voltage".
To check if this is the problem:
-disconnect the modes_of_op pdo (0x6060) from the CIA402 opmode pin in the hal
-start linuxcnc, don't enable the drives / control
-set the lcec.0.X.modes_of_op (0x6060) pin manual to 8 , per halcmd or halshow
-read out the "opmode-display" pin -> should be 8 too
-try to enable the drive
