Linux PRE-EMPT & EtherCAT
- muhosevo
08 Mar 2023 12:19 #266111
by muhosevo
Linux PRE-EMPT & EtherCAT was created by muhosevo
Hi everyone. I'm very very new to the forum. I have a question about EtherCAT. I have a Linux Pre-emt RT patch. Is it possible to control a servo motor using ethercat with c++ with exact precision? Do I need anything else? I wish, my question is clear. Also, I want to explain my project.
I want to make my own 5 axis cnc software for a commercial purpose. I have a program that extracts the G-Codes of any DXF file. And I want to control servo motors w.r.t gcode. I will use Linux Pre-empt, and soem to control servos. Is it possible to make such thing? Do i need anything else?
Finally one more question. Is it possible to LinuxCNC instead of SOEM?
- Thank you received: 4149
08 Mar 2023 20:34 #266147
Replied by rodw on topic Linux PRE-EMPT & EtherCAT
Linuxcnc uses the etherlabmaster master from iGh. To install ethercat with linuxcnc, follow the steps in the sticky in this section
forum.linuxcnc.org/ethercat/45336-etherc...-how-to-step-by-step
PREEMPT_RT is a prerequisite for linuxcnc.
If you use Linuxcnc V 2.9 and above, a number of 5 axis simulations and kinematics modules are included. The switchkins simulations include a 3D model of the machine so you can experiment without hardware. They are called switchkins becasue they allow switcing between conventional 5 axis milling and Tool Cetnre point control.
Finally for a shortcut, you can install Debian Bookworm (Debian 12) as it includes linuxcnc in the Debian repositories. The PREEMPT_RT image is a dependency of linuxcnc so it will get installed with linuxcnc if you type:
sudo apt install linuxcnc-uspace linuxcnc-uspace-dev
- muhosevo
15 Mar 2023 15:58 #266757
by muhosevo
Replied by muhosevo on topic Linux PRE-EMPT & EtherCAT
Thanks for reply.
Can Linuxcnc + ethercat use for time-critical operations? What is the cycle time of one ethercat frame? Also, is Linux-Preemt enough? Because, i heard from someone that linux had the worst real-time kernel. Is it right? How can we measure cycle time of a motion?
15 Mar 2023 20:34 #266785
drive.google.com/file/d/19VggxoJGlKLrIm4...H2M/view?usp=sharing
Page 51: 1000 distrubuted I/O in 30 usec.
Linuxcnc reads the ethercat master every 1 millisecond.
PREEMPT_RT is a hard real time OS but it is affected by jitter, (the amount by which a process runs late or early)
As long as Linuxcnc has enough time left in that 1 ms after allowing for jitter, there is not a problem
ETHERCAT is the most efficient industrial control protocol, Refer P40 which shows it has stack delays orders of magnitude lower than other methods.
OF course they can. Here is a recent paper presented by Marten Rosten head of the Ethercat Technology Group at a recent event I attendedThanks for reply.Can Linuxcnc ethercat use for time-critical operations? What is the cycle time of one ethercat frame? Also, is Linux-Preemt enough? Because, i heard from someone that linux had the worst real-time kernel. Is it right? How can we measure cycle time of a motion?
15 Mar 2023 20:36 #266786
And to explore linux real time jitter, you could use cyclictest
sudo apt install rt-tests
man cyclictest
man cyclictest
- Thank you received: 7478
15 Mar 2023 20:43 #266787
-LinuxCNC is free software with open source code. Current versions of LinuxCNC are entirely licensed under the GNU General Public License and Lesser GNU General Public License (GPL and LGPL).
Replied by tommylight on topic Linux PRE-EMPT & EtherCAT
You should read the License before jumping in like that, a short snippet:I want to make my own 5 axis cnc software for a commercial purpose.
- muhosevo
16 Mar 2023 07:27 #266806
by muhosevo
does it mean can not I use it for commercial purposes?
16 Mar 2023 09:29 #266815
You can use linuxcnc for commercial purposes but you need to respect the GPL license and make the source code available. Tormach is an example of a commercial cnc company who uses linuxcnc and respects the licence (and has contributed to the core code). I am sure many other companies use linuxcnc too.
You will also be using the iGH etherlabmaster ethercat master. It is also open source so there will be other similar GPL requirements there.
Also your company needs to become a member of the Ethercat Technology Group (which is free) to sell ethercat based machines...
The following user(s) said Thank You: tommylight, karoria
16 Mar 2023 11:15 #266823
It is as simple as that.
Best way would be to fork it on github and post changes there, makes things very easy.
You can use it, but any changes you make you must make awailable.does it mean can not I use it for commercial purposes?
16 Mar 2023 11:26 #266825
You need to treat the licensing seriously becaue it will be the free software foundation that prosecutes you and they are well resourced.
There is no need to do this. Tormach don't. They make their source available via a USB stick which they sell for $10 or so which is well within the licence conditions. Note that your application is a derived work so any changes you make or code you write must also be made available.
Time to create page: 0.728 seconds
