Linux PRE-EMPT & EtherCAT
- muhosevo
16 Mar 2023 15:49 #266841
by muhosevo
Replied by muhosevo on topic Linux PRE-EMPT & EtherCAT
can you explain with more detail ?
I want to make a 5 axis cnc software for my customer. However, i will design new ui. also i will add new things that not include in standard ui of linuxcnc and i dont want my customer to know i am using the linuxcnc. Also i dont want to share the codes?
This all considerations is not possible? İf it is possible, what can i do?
- Thank you received: 4128
16 Mar 2023 19:51 #266857
Replied by rodw on topic Linux PRE-EMPT & EtherCAT
I think the best answer I can give is to read the licenses in the copying and copying.more files that ship with Linuxcnc
copying.more is here github.com/LinuxCNC/linuxcnc
There appear to be provisions there that would allow what you want to do if you go about it the right way. Take your own advice on it.
There are many commercial machines or hardware devices that use open source software. eg a Netgear or Dlink router comes to mind.
Time to create page: 0.315 seconds
