ethercat: /lib/x86_64-linux-gnu/libstdc++.so.6
- gueee78
- Thank you received: 4
07 Aug 2023 07:25 #277200
by gueee78
Replied by gueee78 on topic ethercat: /lib/x86_64-linux-gnu/libstdc++.so.6
Hello Rod!
Yes, I exactly followed your sticky thread, except the ethercat master part, since I unstalled it from Bjarne's repo.
Was I supposed to install the ethercat-dkms, libethercat, libethercat-dev and ethercat-master via apt anyway?
- Thank you received: 4128
07 Aug 2023 07:51 #277203
Replied by rodw on topic ethercat: /lib/x86_64-linux-gnu/libstdc++.so.6
I'm not sure yet as I have not tried. But I am sure you will need to change the contents of realtime.mk as per the part in the spoiler.
- gueee78
07 Aug 2023 08:47 #277207
by gueee78
I needed to install the packages and now it's working, thanks again!
So for everyone who needs it here are the steps I took:
1) a fresh install of debian 12.1 as recommended in Rod's sticky
2) install lcnc 2.9 from repos
3) install ethercat master from Bjarne's repo. instructions can be found at gitlab.com/etherlab.org/ethercat/-/issues/61
4) install kernel headers, build-essential, ethercat-dkms, libethercat, libethercat-dev, ethercat-master via apt
5) edit /etc/ethercat.conf, add6) back to RodW's sticky following the rest of the steps starting from
I hope it'll help!
Thanks to all for your support!
MASTER0_DEVICE="xx:aa:yy:zz:bb:cc" and DEVICE_MODULES="generic"sudo systemctl enable ethercat.service
sudo systemctl start ethercat.service
sudo systemctl status ethercat.service
sudo chmod 666 /dev/EtherCAT0I hope it'll help!
09 Aug 2023 04:15 #277400
The first post in the sticky thread has been updated with the current process (including the secure boot)
forum.linuxcnc.org/ethercat/45336-etherc...-how-to-step-by-step
Any testing or review would be appreciated. I have not tested on real hardware. I am expecting a second NIC to arrive tomorrow and I will set up some slaves.
The installation is actually easier now with the way the keys are installed etc.
Many thanks for your work here. visited your issue and after a bit more help, I got ethercat installed on my Secureboot machine.Thanks for your reply!
Meanwhile I went over to gitlab and first tried to compile ethercat-master, with no success.
Fortunately Bjarne von Horn jumped in and gave me the link to his home repo and that actually worked.
gitlab.com/etherlab.org/ethercat/-/issues/61#note_1501705278
The following user(s) said Thank You: jjdege
- jjdege
- Thank you received: 37
09 Aug 2023 10:13 #277414
by jjdege
Replied by jjdege on topic ethercat: /lib/x86_64-linux-gnu/libstdc++.so.6
09 Aug 2023 11:36 #277427
Great, did you follow the updated sticky above? Someone is saying it did not work for him on that thread.Hi everyone
I had the same problem, now with the new indications it is solved and it works well even on real hardware
thanks for the work done
- jjdege
09 Aug 2023 14:05 - 09 Aug 2023 14:28 #277442
by jjdege
yes sure rodw, i used this:
and commented out the old repository in sources.list
Thank you
Thank you
Last edit: 09 Aug 2023 14:28 by jjdege.
Time to create page: 0.167 seconds
